Blown Turbo - Defender Source
Old April 7th, 2012, 11:19 AM
FLRover
Richard
Blown Turbo
This is according tony mechanic: The bearing went out on my turbo and it caused the turbo to dump quarts of oil down the exhaust. My mechanic has since replaced the turbo and the truck is running great. My question is how long should it take for the oil to burn out of the exhaust? It still has "fresh" oil at the tailpipe. Paranoid that it is still leaking oil into the exhaust. Mechanic assures me that it is not.
Motor is a rebuilt 300 Tdi.
Old April 7th, 2012, 11:52 AM
when this happens, you can't just replace the turbo and be done. He should have pulled the intercooler and all the hoses and cleaned them out. If he did not pull out the intercooler...well there you go. From the turbo it is a straight shot of pipe to the muffler and out.
Old April 7th, 2012, 12:13 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Heating up the exhaust system, after you clean out the intercooler & air intake pipes, will go a long way to getting the oil out of the exhaust system. Short runs around town will not help much, you're going to have to have sustained hot exhaust to "burn" it out.
Take a full tank of fuel, run it continuously in 3rd gear until consumed...... and call me in the morning.
Old April 7th, 2012, 01:29 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Lucky it wasn't the intake side. It would have enabled the engine to run on it's own engine oil probably revving to oblivion.
------ Follow up post added April 7th, 2012 06:33 PM ------
The intercooler might not have much oil in it if it was the exhaust side that failed.
Might take quite a bit to burn the oil out of he exhaust.
Mike Hammond
Old April 8th, 2012, 09:03 AM
FLRover
Richard
Thank you for the information. Assuming he did not clean out the intercooler and pipes- is that as simple as removing a few clamps and hoses and then rinsing them with a hose? How would I check/clean out and residual oil. Assuming the full tank and 3rd gear means drive it around on the highway and that will burn the oil out of the exhaust.
Thanks again- appreciate the information for a rookie like me.
Old April 8th, 2012, 10:33 AM
you should be able to disconnect the lowest pipe on the intercooler. Put a finger in there and see if there is oil.
You can feel it / see it on your finger. Water by itself won't clean out oil. Most people use mineral spirits or some other hydrocarbon based solvent.
Old April 8th, 2012, 11:10 AM
yep. don't use water. you can use parts cleaner or the mineral spirits, or diesel. something like that. all you do is disconnect the intercooler hoses, then remove the the top slam panel that is over the radiator/intercooler assembly, and pull it out. Then put it on it's side outside the truck, and the cleaner and slosh it around like you were cleaning dishes. pretty simple.
Old April 8th, 2012, 02:32 PM
mikeslandrover
Mike Hammond
Make sure you get all the solvent out before reconnecting the the intercooler or there would be a very nasty over revving accident waiting to happen.
I wouldn't run anywhere on the open highway in 3rd for long, just pick a route with plenty on long open roads where you can run at full throttle to build up some heat in the exhaust, a good blast will clear the soot from the exhaust for the MOT emission test.
Mike Hammond
DIY VNT turbo for 300TDI? jaherring Defender Technical Discussions 47 August 15th, 2013 07:26 PM
Turbo factoid Overlander Defender Technical Discussions 2 January 15th, 2011 01:32 AM
remote turbo? Rod Hayward Defender Technical Discussions 7 January 11th, 2005 04:16 PM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
