Blown ignition coil - Defender Source
Old June 6th, 2016, 10:00 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Blown ignition coil
Hi all. So I recently swapped out the distributor on the 94 D90 NAS. Went with a Mallory. I also got the other stuff that Mallory recommended for it including the ignition coil.
It ran awesome for 2-3 weekend. Strong. Then out of nowhere it stalled and wouldn't restart. No spark coming from the coil. Power going to it. Fried coil in a brand new setup? Mallory product. It also came with a resistor and a little black plastic box power thing (sorry not a mechanic).
So any thoughts as to why the coil is blown?
Thanks in advance.
-Steve
Old June 6th, 2016, 10:29 PM
I'm switching my stuff out from Mallory - I'd suggested you do the same a while back. My truck was the most dependable car I'd ever had until the Mallory. Maybe it's because I never did the curve thing on it, but I also shouldn't need 2 coils, 2 ignition modules, etc. to have the thing run right for a bit. I'm switching back to OEM.
Old June 6th, 2016, 10:31 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Oh man. I just switched to Mallory. OEM was blowing up my coils too. Now that I think of it, there has to be a deeper issue if different distributors are blowing up coils.
Old June 7th, 2016, 08:01 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I'm running their basic coil w/ zero issues. What coil has been giving you problems?
Old June 7th, 2016, 09:37 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I've had one of these in my truck now for a couple years. It has been fantastic. Maybe an alternative for you guys and your mallorys. OEM sucks.
Performance Distributors - Performance Distributors
Old June 7th, 2016, 10:09 AM
I had a Pertronix installed, I am going to fix the stock and reinstall. I dont know what it is about aftermarket coils and distributors and these trucks
Old June 7th, 2016, 10:39 AM
Haha did you not get my e-mail the other day? I'd asked you to document your set-up since you've seemed to not have issues.
Old June 7th, 2016, 10:41 AM
Last time I'd asked you'd said you'd switched to Mallory like 5 years ago (albeit you may not have fully installed it due to training, etc.).
Old June 7th, 2016, 09:51 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
So true! But here's the funny part. It hasn't been running for 5 years. I bought the Mallory setup. Then my wife went and had twin girls. The D90 sat in a barn (literally) for a few years. Now she's back. So the Mallory is 4ish years old but brand new like 5 running hours ago.
Make sense?
Old June 8th, 2016, 12:34 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have been running mallory for about 10 years or so. It is mostly solid, but components have died. I just changed my coil (first time away from stock)and I have had a ballast resistor fail. I used MSD Blaster 2 with ballast resistor since I was neaar a Pep Boys and it runs fine again. (It was stock coil, probably in the 200K range). Distributor seems to be flawless--I have had faults, but more me experimenting and not knowing what I was doing. And technical issues like not adjusting the timing advance in the coil and not knowing the difference on when I need a ballast resistor or not...
But as far as reliability, I wouldn't hesitate to do a mallory again.
coil
Coil Immobilizer - Genuine Land Rover Part AMR4897 - COIL ENGINE IMMOBILIZER Ben01 For Sale - Parts 1 January 17th, 2016 05:40 PM
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
Ignition/coil to EUC Mike Hippert Defender Technical Discussions 6 March 7th, 2005 02:36 PM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
