Blowing wiper/speedo fuse like crazy....help! - Defender Source
Old March 11th, 2004, 10:14 AM
P1CR
Mazen Fawaz
97' D90 SW, Arles Blue
Unhappy Blowing wiper/speedo fuse like crazy....help!
My wiper/speedometer fuse blew, and blew, and blew.
I mean, when I install a new one, sparks, a flash of light, and it's gone instantaneously.
what the hell?
Any thoughts? Let me guess. A short somewhere.
Maz
97' D-90 SW
Arles Blue
Old March 11th, 2004, 10:17 AM
P1CR
Mazen Fawaz
also...
If it means anything...my temp adjuster thing is totally stuck. Will not slide up and down at all. This happened all the sudden. a couple day before the fuse blew.
Maz
97' D-90 SW
Arles Blue
Old March 11th, 2004, 10:48 AM
Sounds like something wore a hole thru the insulation on a wire. I would pull of the instrument cluster (total of 4 screws) and take a look behind it. Hope that is at least a direction to head.........
You are right ya got a short. What you need is a ohm meter and ALLOT of patience. If you can disconnect everything from the fuse, put a new fuse in and connect things one at a time until the fuse blows again.
The heater control is a cable thing and something probably got jammed in the linkage.
Old March 11th, 2004, 03:23 PM
P1CR
Mazen Fawaz
Unfortunately, I don't have a moment free to get in there and look. It's going to the shop.
Hope it's not going to break my bank!
Maz
97' D-90 SW
Arles Blue
speedo, wing
Fuel injection system Maxi fuse blowing ? TND90 Defender Technical Discussions 4 August 24th, 2009 12:32 PM
Blowing the gauge/brake light/blinker fuse R-C Defender Technical Discussions 3 May 20th, 2008 05:40 PM
Side lights fuse blowing owen Defender Technical Discussions 2 May 5th, 2008 10:59 AM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
