Blowing the gauge/brake light/blinker fuse - Defender Source
Old May 20th, 2008, 11:39 AM
R-C
Chris Schramm
1995 D-90 ST
Smile Blowing the gauge/brake light/blinker fuse
Hey guys, I need some help. My 90 is blowing the fuse that controls the brake lights, blinkers, and fuel/temp guages. The fuse blows immediately when turning the ignition to on and before using either the brakes or turning on the blinkers, so I suspect the wiring related to the two guages. Any suggestions on where to begin? Anyone had a similar situation?
I suspected the rear center brake light fixture because it has some corrosion, but ruled that out because the fuse blows without activating the brake lights. Am I right to rule it out? Any other way that circuit could be the problem?
Thanks in advance, my arm is getting tired of being the brake light and turn signals.....
RC
2003 RR MKIII
1995 RRC County
1995 D-90 ST
Old May 20th, 2008, 12:35 PM
Pat's Avatar
Pat
Patrick M.
D90 '96 300Tdi 5 speed
+12 goes to ground somewhere...
with everything off, unplug the fuse, connect a 12v test lamp where the fuse was connected and check everything related to that fuse until you will find the problem where the test lamp goes off.
Old May 20th, 2008, 01:15 PM
R-C
Chris Schramm
1995 D-90 ST
so that is very helpful...and reminds me that the circuit problem could be anywhere despite the "off" or "on" position...starting with my brake light suspicion...stay tuned.
RC
2003 RR MKIII
1995 RRC County
1995 D-90 ST
Old May 20th, 2008, 05:40 PM
Pat's Avatar
Pat
Patrick M.
well, no really anywhere; the attached image can help you finding where the problem can be located
Pat
brake, ht, wing
Fuel injection system Maxi fuse blowing ? TND90 Defender Technical Discussions 4 August 24th, 2009 12:32 PM
Side lights fuse blowing owen Defender Technical Discussions 2 May 5th, 2008 10:59 AM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
