Blowing fuse on marker light Atlantic British harness - Defender Source
Old October 4th, 2014, 08:58 PM
Pwo
Porter
94 NAS D90
i installed the Alantic British trailer harness and the marker light fuse for the left side blew. All is good with the install. The marker lamp fuse is 7.5 amps and The trailer has 8 lamps on this circuit. I installed a 10 amp fuse to cover the added current and inrush and no more problem. Has anyone else run across this? 94 NAS D 90. Thanks
Old October 5th, 2014, 03:34 PM
Pwo
Porter
94 NAS D90
Question
Bump, anybody?
Old October 5th, 2014, 03:38 PM
No but there is no way 7.5 amps is adequate for 8 normal lamps. You can check the wattage of the bulbs and figure his out.
Old October 5th, 2014, 07:14 PM
Pwo
Porter
94 NAS D90
Thanks I'll have to do the calculations, the wire appears to be 16 gage ,so 10 amps at 14 volts should be ok.
Old October 5th, 2014, 08:26 PM
chuckc4
chuck b
Registered User
Deleted my reply because it was unhelpful after rethinking it.....
Old October 5th, 2014, 08:39 PM
Pwo
Porter
94 NAS D90
Thanks Chuckc4
Grounds are not a problem. All lights are bright, this bass boat trailer has a lot of marker lights. My diesel f250 has no problem but domestic cars use the tail lights and brake lights left and right on the same circuit, un like the rover with circuits for left side and right side for marker lights, tail lights and head lights separate. I was curious if anyone else had to increase the amp rate on this fuse with this setup.
ht, wing
Installed Alantic British trailer harness and blowing fuse Pwo For Sale - Vehicles 0 October 4th, 2014 08:50 PM
Atlantic British/British Pacific Merger brn24whl The Vendors Loft 93 May 23rd, 2013 04:39 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
