Blower - heat - Defender Source
Old January 18th, 2015, 10:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
Blower - heat
How do you know if your blower is done?
Turn on fan, nothing happens. All fuses are good. Remove vent cover from wing and nothing blocking the fan. Fan spins freely but when I spin it, it sounds like it is full of water.
Ideas?
Old January 18th, 2015, 10:22 PM
Check the ground. Failing that, run power directly to it to see if it spins. If that does not work, then replace it.
Old January 18th, 2015, 10:26 PM
Ideas?
Water in La ?
Most likely your switch.
Old January 18th, 2015, 10:42 PM
bjf's Avatar
bjf
barry f
94 ST #395
Where is the ground and by switch do you mean the one in the truck? I took apart dash and the switch looked like the contacts were clean.
Isn't the fan part of the heater box?
Old January 18th, 2015, 10:50 PM
of course the fan is part of the heater box. You can unplug the heater box and run 12v and a ground to the plug and determine if the motor is the problem. I do that before taking the dash apart, that's how we do it on the East coast.
Old January 18th, 2015, 10:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will try that? Can I assume the water sound when spinning is not normal.
Old January 18th, 2015, 10:54 PM
Not normal. Park next to a sprinkler ?
Old January 18th, 2015, 10:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Not sure.
Maybe someone peed in it
Old January 18th, 2015, 10:57 PM
Not sure.
If you were here it would be frozen so there's your up side.
Old January 18th, 2015, 10:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
So true.
By the way should it spin clockwise or counter?
Old January 18th, 2015, 11:03 PM
Been drinking since 3rd quarter of the Seattle game and can't remember @ this juncture. Text me tomorrow and I'll spin one up for point of reference.
Old January 18th, 2015, 11:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks man
Old January 19th, 2015, 04:25 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone have a picture of how to hook up direct power?
I can't figure it out and Dougie Fresh isn't returning my texts.
Old January 19th, 2015, 04:45 PM
On a normal Defender... There are two wires coming from the motor that go to a two wire plug. One wire is green and the other purple. Purple positive, green negative. That connects into the heater resistor pack and you get a three prong connector. Purple/Green +12V, the other two go to ground for the two different speeds.
Old January 19th, 2015, 05:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks for the pic. I went and poked around a bit. The issue turns out the switch in the truck wasn't plugged in.
I'm a dope.
Old January 19th, 2015, 05:59 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Another way to look at it is it didn't cost anything to fix!
Angus
Need help with heater blower motor! Firefighter2904 Defender Technical Discussions 27 October 15th, 2007 09:51 AM
NAS 110 Heater/AC Combo Blower COSteve Wanted 2 July 27th, 2005 02:50 PM
A/c blower motor Campbell Defender Technical Discussions 1 September 27th, 2004 08:19 AM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
Fan blower switch not working draaronr Defender Technical Discussions 3 August 24th, 2004 11:26 AM
» Defender Registry
Red
KGH
Aurora
Glenn_Guinto
Add your Defender
