Blower Disassembly / Cleaning Advice - Defender Source
Old January 19th, 2018, 09:43 AM
mgrgpg
Mark
1989 D110
Need to get the red dirt out of the blower assembly before my rebuild starts.
Looking for advice on the best way to take it apart for cleaning. Shop diagrams look pretty straight forward but want to be safe before I start to dismantle it.
ID:	347225   Click image for larger version
Old January 19th, 2018, 11:27 AM
Chris B
72 + D1 drivetrain =?
I would definitely be looking for some kind of replacement foam seal and heavy doses of windex to clean surfaces....
Old January 19th, 2018, 12:34 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Looks like you need a HEPA filter.
Old January 19th, 2018, 02:54 PM
roverguy2's Avatar
roverguy2
Brian Morton
1991 Defender 110 "Blanca"
Mine looked a lot like yours with heavy dirt caked on with water over time. Compressed air and small brushes got mine clean with some mild soap in the mix. Didn't take it all apart either just took time to clean.
As stated replace the seals the one between the fender and the assembly was like a rock in my truck.
Depending on your final use you may want to look into a snow cover as it has kept the direct dirt and dust from entering my fresh air intake after the rebuild. It's also not bad for rain and snow. Bearmach and many others sell for cheap in the UK.
advice, assembly
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Advice on cleaning engine rayfi Defender Technical Discussions 2 October 30th, 2008 02:56 PM
louder horn advice chirider Misc. Chit-Chat 9 April 8th, 2008 04:49 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
» Defender Registry
Ninety
The Dro
Blue Mule
don
Add your Defender
