Blow-by? 200tdi - Defender Source
Old June 15th, 2015, 08:58 AM
Blow-by? 200tdi
OK so with several hundred miles on this (used) engine it seems to have two symptoms which make me think I have a problem. First is it seems down on power; it struggles to get to 60 on the highway.
Second is a huge amount of pressure under the valve cover. So much so that it is literally blowing engine oil out from under the gasket all the way around. I even have the vent hose pointing to the road so it doesn't fill my intercooler with oil.
It doesn't seem to be smoking at the tailpipe excessively .
Am I on track for a ring job or what?
Old June 15th, 2015, 09:14 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I have the same issue with mine only it doesn't seem down on power. Maybe because I've upped the fueling/boost and have a full width intercooler, straight through exhaust etc. I've checked the breather and it's clear and I've replaced the valve cover gasket a few times. I figure rings are the only logical explanation.
Old June 15th, 2015, 09:54 AM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
Does it smoke/blow oil at start up or once it gets to temp?
Old June 15th, 2015, 10:05 AM
Not smokey
Old June 15th, 2015, 10:56 AM
Do a leak down test (air line into each cylinder with valves closed). It is pretty common to get a head gasket leak into the push rods area on #4. The leak down test will tell you pretty quick if it is a head gasket or rings.
There should be no noticeable pressure in the valve cover when things are good.
Old June 15th, 2015, 11:22 AM
I do recall it took some time to get up to speed when I test drove it. That engine was a known quantity and running well when Neil had it in his 110. I rode in it with him on various occasions and there was no indication of problems, though it was a leaky mess which I attributed to the rear main seal.Of course that was all some years ago now. Did you do anything in the way of reconditioning the motor? Sounds like at least a compression test is in order.
Full disclosure, I sold Bill the engine.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 15th, 2015, 11:39 AM
Yeh It needs a compression test, but that will probably only serve to confirm. Maybe it is just a gasket like John sez. It does run fine, starts right up and is way way more powerful than the 2.25.
What I'll probably do is get the 300tdi lump done up all shiny-like and then next year or so just do a switcheroo. Then either pass the 200 along or recondition it.
200tdi, tdi
Detroit Locker Blow out Fivespddisco The Vendors Loft 0 February 4th, 2011 11:21 PM
Did I blow up my diff?? TexasD-90 Defender Technical Discussions 29 January 5th, 2011 07:54 PM
Parts Blow Out Tennesse CDeWan The Flea Market 3 June 3rd, 2010 10:53 PM
Door Innards Blow up/ picture.. mightymg Defender Technical Discussions 1 October 25th, 2009 09:41 PM
$1500 to blow gtg067i Defender Technical Discussions 18 November 2nd, 2005 09:11 AM
