Blocking Cab Heat... Exmoor moulded matting? - Defender Source
Old December 25th, 2011, 07:38 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Been reading a bit on the subject, but trying to get some current opinions on how to keep the heat in the SW to a bearable level. I've seen people use products like Lizard Skin, Dynamat, etc. - then cover with rhino liner or the like. I am worried about the occasional water that gets onto the floor, so whatever I go with, I have to make sure I won't be promoting a rusty environment down here in damp south FL. The floor / bulkhead behind the gas pedal had to be over 120 degrees today... and it's December! Wondering if anyone has experience with the exmoor moulded / insulated matting (like Safari Resto sells). Maybe something like this over a thermal barrier? Any help / suggestions of things to look into, or even stay away from would be greatly, greatly appreciated!
Thanks so much in advance
-Aaron
Old December 29th, 2011, 02:49 AM
CDeWan
Clay DeWan
5.3L beastie
Possibly wrapping part of the exhaust - Not all but from the behind the Cats to the Y pipe.
Think about the exterior and ways to deflect heat from the firewall.
I put some reflective material on the firewall and above the tranny to reflect the heat downward. I think I picked up some stuff at summit or crutchfield.
Also, you may want to mount a few of the asbestos type silver heat reflectors around the top part of the cat to keep the heat out of the cab.
I couldn't imagine driving one of these in FL. O and Go USF bulls (alumni .
Old December 29th, 2011, 07:04 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you are too hot you can use the reflective matting on the transmission hump, and the firewall. You can use it on the floorboards but if you make it removable so you can take it up after the rains. That, I would think, should take care of it.
Land Rover 110
Old December 29th, 2011, 09:14 AM
Naplm00
Matthew
summit and jegs both carry exterior and interior heat resistant stick on padding, they also carry underhood heat pads
Old December 29th, 2011, 11:58 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Well at least someone is getting to much heat outta Rover! I've been working hard to kept a bit of warm in my 110 for years.. There`s no justice in this world......
Old December 29th, 2011, 02:36 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Haha... The grass is always greener!
Thanks for all of the suggestions... Quick question tho, how does the heat insulation hold up on the outside of the vehicle with respect to mud and general offroading?
I think I may get the exmoor matting anyway since most of the carpet is shot in the front. Wasn't too sure how some of these Interior insulatin sheets hold up with respect to moisture after getting wet - I do like the idea of not permanently attaching them if using on the interior.
Anyone used Lizard Skin with success or failure? Heard Dynamat wasn't too great with blocking heat.
As always, thanks so much in advance!
Aaron
exmoor
Heat Sheild Bowtracer Defender Technical Discussions 14 July 7th, 2007 12:11 AM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
Pickup cab and custom cage dave_lucas For Sale - Parts 11 January 7th, 2004 10:12 PM
What Parts Are Needed For A P/U Cab? javelinadave Defender Technical Discussions 6 October 25th, 2003 09:48 AM
