Blockheater suggestions - Defender Source
Old January 16th, 2018, 07:12 AM
marcd's Avatar
marcd
Marc Wiener
1989 Classic convertible
Hey guys- I have an 85 3.5v8 that has been running great. I want to add a block heater, any suggestions here?
85' Defender 110 v8
Range Rover 87' County- convertible
Range Rover 2004 HSE Westminster
Land Rover Discovery 2 - 2000
Land Rover LR4 2015 HSE LUX
Old January 16th, 2018, 07:47 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You can stick one of these sump heaters on in about 10 minutes....
Warms the oil; won't help you get cabin heat much faster...
Rent my
Old January 16th, 2018, 10:26 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
The lower rad hose type are easy to install if you don't want to mess with a frost plug. I've used both types and they both work well even in the -30c range.
Old January 16th, 2018, 10:34 AM
I have been using one of these on different engines around the farm to include the Massey ferguson and John Deere tractors (ie lots of iron to warm up).
Magnetic so no install, just open the hood and stick it to the block, plug it in for 30 mins, and the engines have started right up.
https://www.tractorsupply.com/tsc/pr...ter-200w?rfk=1
Old January 16th, 2018, 10:46 AM
Frost plugs are 1.5". Temro/Zerostart part number is 3100039. Common heater used is lots of cars, so should be easy to find. 600 watts right in the coolant. More work than other options, but nothing works as well as a frost plug heater.
https://www.amazon.com/Zerostart-310...heater+3100039
Looking for Front Seat Suggestions smenzel Defender Technical Discussions 39 February 26th, 2006 07:55 PM
Roof Rack Suggestions skibigwest Defender Technical Discussions 1 February 21st, 2006 02:55 AM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
Lube Suggestions TDI Guy Misc. Chit-Chat 7 January 19th, 2004 07:56 AM
» Defender Registry
95 RRC
WeBeCinYa
248
xjahx
Add your Defender
