Block sealant (was coolant gasses in rad) - Defender Source
Old April 27th, 2005, 09:12 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Well, I FULLY flushed out all the coolant, opening both engine drain plugs and flushing tons of water through the engine and radiator. I then added K&W Block Sealant (also known as liquid glass) and ran the engine at idle for about 40 minutes then drained and let dry 6-24 hours. I let it dry 46 hours. I just flushed, refilled and then fitted a "proper" resevoir--I picked up one of those big black range rover resevoirs that hook into the lower radiator hose and then I cut the suction hose for the heater and "T"ed it into it. I refilled everything. I just ran the truck on the freeway (it just started snowing again in Colorado) for about 20 minute to a store and then home and the fluid levels look right and I used my block tester and it showed no signs of gasses in the exhaust. In otherwords, so far it looks like it solved my leaky block (either a porous block or a slipped cylinder are most likely causes). I will give a couple of follow ups to this post to check the progress in case anyone else wants to try out this method. I will take the truck to work tomorrow to truly check it out (45 minutes each way on freeway).
Best regards,
C
Old April 27th, 2005, 11:13 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Wow, good news Chris. Hoping to hear that this is a permanent fix!!
Doug W.
Old April 27th, 2005, 11:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Sweet! Glad to hear it's on the road again.
Now, what's this about a different reservoir? Perking my interest there.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 27th, 2005, 11:55 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Well, those small crappy metal ones are just too tiny and there is no recyling back of fluid. New radiator coolant resevoirs typically have an overflow into the fluid and then a return back into the system (usually this return is into the lower radiator hose on the suction side of the pump from the radiator, but that proved too complicated a splice so I tapped into the suction side of the heater hose at the recommendation of my buddy who I trust). The heater hose is a 3/4" ID which I used a 3/4" T and then a 3/4-5/8" reducer since the resevoir takes a 5/8" ID hose. This resevoir takes the discovery cap. It is sitting just a little high under the hood, but I will tweak down lower later.
Now when the radiator fluid expands, it fills the tank and when it cools it recirculates right back into the system. Not that the old style does not work, just not as well IMHO.
Old April 28th, 2005, 10:47 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
After 100 miles of freeway and street in a day, everything is fine. I don't want to jinx it now, so I will give everyone an update on this type of product in a month or so after trail testing. So far, two thumbs up!
Old May 15th, 2005, 06:31 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I just went up Carnage Canyon and had a great, warm day out. No overheating, no radiator fluid loss, no exhaust gasses in the coolant. So far so good. I would recommend this stuff pretty hardily right now, and will give everyone a check-back in about 6-months.
Old April 6th, 2006, 01:08 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Just checking back with you all--still no problems and I don't treat the truck too gingerly, either.
coolant, gas
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
4.6 short block vesparover Defender Technical Discussions 1 March 20th, 2005 11:43 AM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
