Blinking brake warning light - Defender Source
Old August 31st, 2006, 05:03 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
While going down hill on rough (really rough) roads the brake warning light (one the dash) blinks and some times stays solid. Brake fluid level is fine. I don;t think the brake lines are streatching but ordered extended steels to be sure... anything else to check... mabyle a loose wire. I checked on the resivior and all looks AOK... because it is the brakes this makes me paranoid.
Thanks all
Old August 31st, 2006, 06:26 PM
Andrew Vick
Andrew Vick
95 D90
Might want to check the wire on the handbrake. Mine was chaffed and that happened. Just taped it up and no more issues.
Old August 31st, 2006, 10:33 PM
D90user's Avatar
D90user
steve
It's not the parking brake light its the other brake light on the dash....
Old August 31st, 2006, 10:50 PM
Andrew Vick
Andrew Vick
95 D90
The ABS light? Red or amber?
Old August 31st, 2006, 11:59 PM
D90user's Avatar
D90user
steve
Red. It has an "!" and "Brake" written on it....I dont have ABS.
thanks for the input
Old September 1st, 2006, 12:55 AM
My Tdi is doing the same thing. I havent had a chance to trouble shoot it, much less figure it out. Both that light and the P-brake light have always come on when I set the parking brake though, so they are somehow related.
Old September 1st, 2006, 12:58 AM
D90user's Avatar
D90user
steve
This is also on a tdi... My '!' light does not come on when I set the parking brake... jsut the park brake light... Interesting you are having the same problem Jim. Is it also happening to you only on rough roads or in normal driving?
Old September 1st, 2006, 01:39 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
suckers think you`ve got the one up with your fancy tdi`s
Old September 1st, 2006, 05:45 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
its the fluid level sensor in the brake master cylinder, either fluid level is a bit low, if not try rotating the cap slightly so the so the sensor is rotated in the reservoir.
Old September 1st, 2006, 08:17 AM
Noah's Avatar
Noah
Noah
95 D90 TDI
I unplugged that fluid sensor long ago.
Old September 1st, 2006, 11:27 AM
D90user's Avatar
D90user
steve
lol
Good thought on rotating the sensor. I checked the wiring and I can find a thing wrong. Fluid level is full... really full.
noah- I don't know if that is such a good idea
Old September 2nd, 2006, 11:17 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I am having the same problem. Mine seems to be fluid level b/c it comes on mostly when turning. But level is full.
Old September 3rd, 2006, 05:31 PM
themaxx's Avatar
themaxx
Ade
94 ST
I had the exact same problem. My brake fluid was full, but when I topped it off anyways, my problem disappeared.
Old September 3rd, 2006, 06:29 PM
D90user's Avatar
D90user
steve
I think Ian was correct with the initial statment of rotating the cap so that the sensor is in a different place and topping off. If fill it really full and I changed the orientation of my sensor to the side... problem is no more.
thanks
Old September 3rd, 2006, 10:26 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Talking
Ditto. I topped it off and rotated the sensor. No more blinking light.
Old September 4th, 2006, 06:20 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
Ah the joys of owning a rover. The best fixes are free
brake, ht
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
