Blinker Problem / Rover Service-- Dallas, TX - Defender Source
Old October 12th, 2009, 01:34 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Anyone on here live in dallas and have a good rover guy?
Here is my dilemma:
My blinkers arent working so I cant pass inspection.
Some diagnostics:
-Fuses are good- both in the cab and under the hood
-Flashers work
-Horn works
-High beams work
Any ideas?
Old October 12th, 2009, 02:33 PM
dbj2003
Brandon Jones
94 Defender 90 POE
Did you check the turn signal switch? Have access to a multimeter to see if it gets power? You could also get your truck inspected somewhere shady.
Old October 12th, 2009, 02:40 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
I'm guessing that it is the switch. It is just odd that the same switch controls the high beams and the horn- and both of those functions are working.
I may have to venture into the depths of the east side to get by this one...
Old October 12th, 2009, 02:44 PM
JRW's Avatar
JRW
94 D90 ST #1247
Call Alan at North Texas Rovers. Very happy with his work, prices and honesty. Best rover guy in town.
Old October 12th, 2009, 03:20 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Talked to Alan. Taking it in for a look tomorrow.
Old October 12th, 2009, 04:42 PM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
Make sure the hazard switch is all the way out. Sometimes it sticks- it won't activate the flashers but the turn signals wont work either.
Old October 12th, 2009, 06:35 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Trae- thanks man. I'll try that when I get home. Could save me a bunch of time and money!!!
Praying for a simple fix!
Trae- my man! Thanks so much for the save! Had my defender 48 hours and I already love this board!
Old October 12th, 2009, 07:18 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Aww, Trae, you beat me to it!
Email is
Same place, new dogs.
Old October 12th, 2009, 07:22 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Maybe you guys will know the answer to this question too....
Is the Sylvania Xtravision H6024 an acceptable replacement headlight with factory wiring? Have to replace it to pass inspection and get some plates on this bad boy!
Old October 12th, 2009, 08:16 PM
texmoto
david summers
99 Discovery II
Is that a sealed beam? If not, strongly recommend up grading to some Hella H4 replacements, which use a commonly available halogen bulb. Drop in mod, NO wire splicing. Offically, they are not DOT approved, but I have never had any problem passing inspection. And I'm in Fort Worth.
Old October 12th, 2009, 08:25 PM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
Ha! You can still have credit, I mean after all you did tell me how to fix it...
Old October 12th, 2009, 08:53 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Thanks for all your help gents!
Old October 12th, 2009, 09:17 PM
That is what I used but both died fairly quickly. I went back to the normal sylvania halogens and they seem to last better.
Old October 12th, 2009, 09:47 PM
Grover's Avatar
Grover
Thumbs up
Also check the terminals and the bulb socket for corrosion. Use di-electric grease on all terminals and bulb sockets...
Good Luck...
Cheers...
Old October 12th, 2009, 11:26 PM
dbj2003
Brandon Jones
94 Defender 90 POE
Sorry if this is stating the complete obvious but be careful not to touch the Hella bulbs with your skin or anything oily during install.
Old October 13th, 2009, 06:44 AM
Roverlab
Trevor Griffiths
Texmoto: For my customer's Rovers, I've been using a non-sealed beam headlamp such as a Hella, fitting any range of high wattage bulbs. But most importantly, I also fit a headlamp wiring harness from Painless Performance P/N 30815. One of your original headlamp connectors plugs in to the harness to trigger a pair of waterproof 40 amp relays controlling the high beam and low beam of each headlamp. This way, one avoids sending the load through the frail Genuine headlamp switch, and gives better brightness due to minimal resistance loss.
It's seamless- nothing changes in the way of on/off or high beam low beam swiitches, but you'll see better.
Trae has it on his D90, and it's been trouble free for years.
But to get through inspection, a halogen 6014/6024 will work.
Trevor
Email is
Old October 13th, 2009, 10:19 AM
GMFett's Avatar
GMFett
Marcus
1994 D-90
I'll be honest- I touched all up on that bulb. I figured since it wasn't one of those little halogen bulbs it didnt matter. Should I take it back out and wipe it all down or just the front glass?
Old September 16th, 2010, 03:01 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
That was the ticket for me too.
service
Famous Land Rover owners Lindy Misc. Chit-Chat 4 June 15th, 2009 08:49 PM
Good Bye Ford, Hello Tata... It's done. JFD Misc. Chit-Chat 46 April 3rd, 2008 02:49 PM
Land Rover family tree D901619 Defender Technical Discussions 9 July 5th, 2007 04:34 PM
White 1995 Land Rover D90 ST (located in Dallas) defender_rd For Sale - Vehicles 1 November 9th, 2004 11:27 AM
