Blinker Issue - Defender Source
Old April 3rd, 2012, 09:02 AM
cthoekenga's Avatar
cthoekenga
1997 BRG D90
Blinker Issue
I recently switched my steering wheel over to a Momo. Since the switch, the blinker will not "click off" on its own after a turn. I have to manually turn the blinker off. Is there any quick fix to this? Thanks in advnce. Craig
Old April 3rd, 2012, 09:22 AM
Naplm00
Matthew
The hub or boss that you attached to the wheel should have a finger of some sort cast into it on the inside. This finger trips the blinker switch and resets it.
Unknown if it would be easy to add one.
Old April 3rd, 2012, 09:38 AM
cthoekenga's Avatar
cthoekenga
1997 BRG D90
Thanks Matthew. I'll take a look when I get home.
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Fuel Pump Issue bjenk Defender Technical Discussions 12 December 5th, 2004 09:00 PM
