Blew u-joint in rear, help on 4 bolts removal on brake drum - Defender Source
Old February 1st, 2012, 11:22 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Need a little help, I blew a u joint in my rear drive shaft on the transfer/brake drum side.
I got my new front heavy duty double and rear shaft delivered today. My question is that does anyone have a diagram of how to remove the brake drum? I sheared of three of the bolts and need to know how to open the brake drum to replace all four bolts? Any tools I might need? Any help or guidance will appreciated,
Thanks, David
Old February 1st, 2012, 11:28 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
undo the phillips head screw and the big nut in the middle. I think its a 32mm? pull the drum off and take the rear flange out.
http://www.landroverweb.com/landrove...-lt230-flange/
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 2nd, 2012, 12:10 AM
You need to first back off the brake shoes. There is an adjuster on the back, that needs to be backed out.
Note that when you remove the drive flange, oil will leak out.
Old February 2nd, 2012, 07:53 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Thanks, I'll be fixin it Saturday morning
bolts, brake
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Help with rear link removal UpnOver Defender Technical Discussions 19 October 22nd, 2009 05:21 PM
3rd brake light assembly, bolts for spare, 90ST cafemosaic Wanted 0 January 24th, 2006 09:23 PM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
Rear seatbelt removal chrisvonc Defender Technical Discussions 2 February 18th, 2005 04:04 PM
