Blew a coolant hose - Page 2 - Defender Source
Old February 20th, 2013, 10:37 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
From what I remember my 2.5 NAD had the same setup a multiple part hose with a metal connector in the middle. It was a heavy duty metal connector with a bead on it so the hose was unable to slip
My 200tdi uses a one piece hose, not sure about the 300?
Old February 20th, 2013, 10:47 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Back along in this tread somebody mentioned a webasto heater is fitted, is this correct? if so why the hell is it plumbed into the rad hose?
A webasto needs to be inline with the heater hoses, not cut into the rad hose using crappy plastic fittings.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 20th, 2013, 10:50 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
The 300 uses a one piece custom molded hose as well. There is also that self-bleed y-pipe venturi thing, but that's a different hose.
Old February 20th, 2013, 11:07 AM
Originally Posted by aosias View Post
obviously i need to find a new mechanic
boom!
Mark Kellgren
KM4BOR
Old February 20th, 2013, 11:24 AM
aosias's Avatar
aosias
Alexandra
1995 D90
It is plumbed into the heater hoses, not the radiator hoses. It's set up to pre-heat the coolant by remote start.
No one piece custom molded hose, instead it is a multiple piece hose held together with clamps and plastic fittings.
Old February 20th, 2013, 11:41 AM
One piece... http://www.paddockspares.com/pch1190...ttom-hose.html
http://www.lrseries.com/shop/product...OR-BOTTOM.html
Old February 20th, 2013, 11:58 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
That is what I was trying to find out. I have seen webasto's plumbed into radiator hoses and if the webasto creates a blockage then you have an issue.
Old February 20th, 2013, 07:41 PM
aosias's Avatar
aosias
Alexandra
1995 D90
The Webasto seems to be plumbed correctly into the heater hoses.
I had a shop look at it and they said all the hoses seem to be leaking in some fashion and are "cobbled together," stretched and frayed. Granted they don't do diesel motors I did get a chuckle out of how they weren't impressed with LR's design of the radiator hose.
I ordered a new top and bottom radiator hose, freeze plug, have a new t-stat and will be getting a new pressure relief cap. Hopefully this takes care of it.
Old February 20th, 2013, 07:44 PM
tjfslaughter
thomas
Burbon
Good luck.
Old February 22nd, 2013, 05:43 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Here are some photos. The Webasto sends coolant to the heater box inlet (the arrow pointing in on the left side) and then the outlet (assume outlet since there isn't an arrow) sends coolant to the back of the motor. The Webasto gets coolant from the long pipe that runs down the top of the motor.
I replaced the expansion cap, and tightened the hose clamps again. Drove the truck around to get the motor warmed up. Heater was putting out luke warm heat that was consistent with the motor temp- starting to warm up.
When I felt the hoses the top radiator hose was cool, the bottom hose was warm. The hose coming out of the thermostat housing was warm and both heater hoses were warm. Should the top radiator hose be cool to the touch?
Water pump pulley has some coolant but not sure if that is residual from the popped hose or or the top radiator hose leaking. Is there any reason for coolant to leak from that area on the pulley?
ID:	66633   Click image for larger version
ID:	66635   Click image for larger version
Old March 4th, 2013, 01:41 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Had the system pressure tested and tested for exhaust fumes. Found a loose clamp and of course the weeping freeze plug. Replacing the leaking/weeping freeze plug. Looks like it was a faulty expansion cap since that is the only other thing I've messed with.
Might be forward progress for the old girl.
Did get a new LR hose and its the same set up- plastic T and all. Trying not to do too many things at once.
Old March 4th, 2013, 02:22 PM
roverman2010
1985 LR 90 200Tdi
roversnoth forum page 300TDI Lower Radiator Hose Warped Fittings
Is this the style of hose you are using? junk the more connections you put into a system the more to fail. Get a one piece molded hose.Click image for larger version
Name:	300tdi crap hose.jpg
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 4th, 2013, 05:16 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Hmmmm
Keith
Big, Red and ... aaa Red..
coolant
Water pump pulley wearing my coolant hose. 300 tdi sundogcwolfe Defender Technical Discussions 11 February 16th, 2012 12:29 PM
D2 4.6 coolant hose clamps JFD Defender Technical Discussions 0 January 16th, 2011 08:22 PM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Block sealant (was coolant gasses in rad) Davis Defender Technical Discussions 6 April 6th, 2006 01:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
