Bleeding TDI Fuel System - Defender Source
Old October 16th, 2010, 04:40 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I recently opened the valve on the fuel filter of my 200 tdi to check for sediment. I also opened my fuel sedimentator and removed dirt from it and metal particles from the magnet. Someone had suggested that I bleed the fuel system or manually prime the pump after these procedures. I didn't as I replaced the fuel filter formerly and there was no apparent ill effect related to not priming. In fact, the car only sputtered a few seconds until fuel got back into the system, and the truck ran fine. Fast forward to the most recent filter/sedimentator cleaning. After cleaning, the truck ran fine. Now(a week later), however, the car sometimes runs a few seconds upon start up and then sputters to a stop. Sometimes I have to start the car 3 or 4 times until it keeps running. I am wondering if this is a result of air in the system. It has also turned colder here, so maybe I just didn't let the glow plugs warm sufficiently. Anyway I would welcome advice on bleeding or priming the fuel system and any direction on exactly how I would go about doing that.
Old October 16th, 2010, 05:15 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
More likely to be the result of an air leak in the fuel system.
Mike Hammond
Old October 19th, 2010, 01:00 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
So... how do you track down an air leak? I have had a similar problem since I did my 300TDI conversion (first it started poorly... then for about a week it was perfect and I barely touched the key... now it's starting poorly *and* idling poorly).
I am waiting for a new lift pump and filter to arrive, but in the mean time, what to look for in an air leak? I don't see any signs of fuel dripping at any of the connections I can see (can't visually inspect the top of the gas tank).
Old October 19th, 2010, 01:07 PM
mikeslandrover
Mike Hammond
Most of the fuel system is under suction so see if any unions are loose. The plastic tube shouldn't be able to rotate on the metal spigot, if it can it could draw in air. That's bad
Mike Hammond
Old October 21st, 2010, 04:38 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Hmm, I think I remember at least one plastic tube rotating on a banjo fitting...
Old October 21st, 2010, 04:47 AM
mikeslandrover
Mike Hammond
Try putting some silicon sealant around the joint. See if that helps.
Mike Hammond
bleed, fuel, tdi
95 D90 Fuel System steinhnj Defender Technical Discussions 8 November 28th, 2008 12:25 PM
Fuel system bleeding CDNRover Defender Technical Discussions 6 July 16th, 2008 01:05 PM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
