Black 'Goop' under clutch/brake pedal Boxes? - Defender Source
Old April 26th, 2009, 11:12 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
What is the black 'goop' between the clutch & brake pedal boxes and the bulkhead? IsS that the infamous Hylomar? I'm getting ready to do the clutch master, and understand the easiest way is to remove the pedeal boxes, what should I use to 'reseal' teeh pedal box to bulkhead union? Thanks..
~Scott T.
'95 D-90 ST - AA Yellow
Old April 26th, 2009, 11:49 AM
It looks like "right stuff" to me although on mine, it is harder, any black hardening silicone would work or you could just buy the proper gaskets. Hylomar is translucent blue.
Old April 26th, 2009, 11:57 AM
EWR's Avatar
EWR
Carey
1954 CJ-3B
It's black 3M strip caulk, A.K.A" Monkey Poop". Not right stuff....
What tree?
Old April 26th, 2009, 02:08 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
So whatever I have there is not stock then? I bought the truck used (in '97 so it was two years old at the time). From what I've seen I'm probably going to have to pull the brake Pedal box off to get at teh Clutch Master, so I will need to reseal both. Fromt he factory there was a gasket? No Sealer other than that? Anyone have the P/N? Thanks..
~Scott T.
Old April 26th, 2009, 03:39 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
I already told you, strip caulk. That's what you need when refitting the pedal box. You'll also need 3M general purpose adhesive remover for the stuff that's on there right now.
What tree?
Old April 26th, 2009, 09:29 PM
Some of them came from the factory with right stuff or some sort of hardening silicone or there was a TSB to recaulk them with right stuff. I assume that is what he has based on his description. My 1995 has it caulked with what looks like hardened right stuff and I have seen it on other trucks. When it is done it looks like someone just caulked it with black caulk. Factory maybe have been strip caulk as that is what appears to be on the donor 110, but the one I took apart (#1466) had a gasket (who knows if it was original). The bottom line is that the gasket, right stuff or strip caulk (provided there are no gaps) will all work. Choose your poison. The yellow is like right stuff and the white looks like it is strip caulk.
Name:	right stuff pedal boxes small.jpg
ID:	19071   Click image for larger version
Name:	strip caulk small.jpg
Old April 26th, 2009, 11:29 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, looks like Right Stuff to me too. Considering Right Stuff seems to be the preferred (by technicians) method to seal just about everything on these trucks, I would say it would be fine. In fact, considering LR's track record with gaskets, it is probably a lot better than any gasket LR offers.
ac, brake, clutch
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Bling - Billet aluminium pedal covers Defender50th Misc. Chit-Chat 2 April 26th, 2005 03:30 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
