Black exhaust 97 NAS - Page 2 - Defender Source
Old April 18th, 2014, 04:26 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Yeah, she's a tricky gremlin and in hoping it's not because of water damage. The comp under the passenger seat has been fully submerged a few times. I'm going to start testing grounds this weekend.
Old April 18th, 2014, 04:32 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by Spenc1tj View Post
Ok I still don't get it. The exhaust was black well before I had the cat hollowed . The exhaust shop hollowed it because it was clogging up. I would not think of hollowing it to make it louder . The hollow one actually sounds like crap because you can hear the exhaust flowing through and almost makes it sound like a leak. So throwing the hollow cat out of the equation and the only code I'm throwing is the ecu having communication problems from a twitchy ground what are the other possibilities? I was thinking plugs, wires and coils would be a good idea but this engine only has 20k miles on it and was installed by LR so that's probably nothing to do with it. I still plan on doing coils,wires and plugs since the engine was installed back in 02 or 03.
I guess I've always figured that all defenders had dark exhaust. Any other suggestion out there?
Perhaps I misunderstood the information,
Here is what I gather,
You had a Check Engine light on since 2002, reset 2 weeks ago
You have a Service Engine light on NOW (which, according to the Owners manual, is a reminder for emissions service)
The 'hollow cat' seems like an interesting choice (I realize it was recommended to you)
The issue is the engine running rich, it seems, and producing carbon.
The temp sensor is a viable solution, I would start there since you have a part number in this thread and its inexpensive ($20)
I am sure if your exhaust is that black, your plugs are filthy, but my suggestion of replacing the o2 and checking the MAF sensor (you can clean them usually) stands as it would cause the symptoms you are describing.
I mean unfortunately you are going to have to wait till the CEL comes on to read the code again and see if one of the sensors is faulty.
Old April 18th, 2014, 04:41 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Thanks ! I'm going to replace the temp sensor for sure this weekend. I'll try and clean the O2 sensors this weekend too if I can get them out. Spark plugs, wires and coils will happen sometime this summer. Also to be clear, the service engine soon light has been on as long as the check engine. You never know with this thing ever since the fire you know? The entire wiring harness and dash had to be replaced so the chance of electrical gremlins is very high I would think.
Old April 18th, 2014, 04:42 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
also check the wiring on the o2 sensors, they do melt if they are run incorrectly, sometimes very discretely too.
------ Follow up post added April 18th, 2014 02:43 PM ------
I don't think you can clean o2 sensors but I don't know that for a fact... also NEVER SEIZE and pb blast them the night before if you want to take them out. I have uttered more expletives at frozen sensors than can ever be repeated...
Wanted: Black or White D-90 Soft or 95 black anmpharm Wanted 20 August 28th, 2010 10:09 AM
Very Nice 1995 Black/Black D90 R-C For Sale - Vehicles 21 June 19th, 2009 09:59 AM
For sale: Badger Bikini Top (Black Twillfast)+ sun roof + black fur seats davidr For Sale - Parts 4 December 11th, 2008 04:59 PM
2001 Range Rover 4.6 HSE Black/ Black Great Cond. treydub For Sale - Vehicles 1 May 22nd, 2007 09:43 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
