Bit size?? Please help! - Defender Source
Old September 7th, 2016, 05:49 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
What size bit/driver do I need for the soft top star bolts on a 97 NAS ST?
Old September 7th, 2016, 06:37 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Do you mean the cage bolts? They're T50.
Rent my
Old September 7th, 2016, 06:45 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Do you mean the cage bolts? They're T50. .
They are called Torx bolts and as Nomar said they are T50.
Old September 7th, 2016, 07:26 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Here they are if you need some new ones
SCREW TORX DRIVE M10 x 30mm, ALR5549 - Rovers North - Classic Land Rover Parts
Rent my
Old September 7th, 2016, 07:38 PM
I'll throw some more detail out there, they are Torx T-50 heads M10-1.50 x 3.175….my understanding is that this cross-references to a Ford part number actually (Part# W504775-S424)...though this is the "urban legend" portion that I've never actually verified.
But...if you can find someone hoarding old Ford parts, you may be able to find the bolts cheap.
Old September 7th, 2016, 08:31 PM
I'll throw some more detail out there, they are Torx T-50 heads M10-1.50 x 3.175….my understanding is that this cross-references to a Ford part number actually (Part# W504775-S424)...though this is the "urban legend" portion that I've never actually verified. But...if you can find someone hoarding old Ford parts, you may be able to find the bolts cheap.
Or pick and pull take them from crown Victoria seatbelt mounts ...
Old September 7th, 2016, 08:46 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
No urban legend. I scooped up two bags off ~15 each new off eBay for cheap. Ask Galpin as I gave him a bag.
Old September 7th, 2016, 08:53 PM
Dry land is not a myth! I have seen it!
Old September 8th, 2016, 12:04 AM
I have a bag too waiting for the day I restore my truck!
Old September 8th, 2016, 01:12 AM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Thanks everyone!
What size thread are the fittings in a steering box? help asap please evilfij Defender Technical Discussions 1 August 3rd, 2009 12:57 PM
Looking for help on What D90 to buy, please help. jamesbash Defender Technical Discussions 20 December 18th, 2007 01:19 PM
Milemarker has a bit to learn about customer service Hans Misc. Chit-Chat 6 March 18th, 2005 05:24 PM
Tyres (again!) + a bit of gearing Berty Defender Technical Discussions 11 September 15th, 2004 02:52 AM
Torx bit size WhiteD90 Defender Technical Discussions 1 September 10th, 2004 08:20 AM
