Binnacle Install - Defender Source
Old May 4th, 2014, 10:57 AM
bneri's Avatar
bneri
1994 NAS D90 soft top
Binnacle Install
Was hoping someone could give me a quick lesson on a binnacle install for a 94 D 90…as typical, the instrument binnacle (or cowl, not sure the difference) had cracked in many places and since I don't want to replace it again in a few years, I ordered the metal binnacle from Raptor engineering as well as the hardware from RN…so back to the question, has anyone done this? Do I need to unplug the instrument panel? Any tips? thx Brian
Old May 4th, 2014, 11:11 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I just did this and it is very easy. Unscrew the screws that hold the fan lever and if I remember the heat/defrost levers. Unscrew all of the screws that hold the gauge cluster on and pull it forward. The speedo cable will have to be disconnected, grab it, squeeze and pull it out. You should be able to get to the screws that hold the plastic cowl in place now. They are on top and tough to get to but not impossible. Once the screws are out just wiggle the plastic cowl out and wiggle the metal one in. You won't use all of the screws for the metal one as there are less holes for them. I used 3 or 4 don't remember but it is solid and much better. Once in just screw everything back together, don't forget to reconnect the speedo cable. Just push it back in.
Hope this helps
Old May 4th, 2014, 11:40 AM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I second Chris' comment. I did this a few months ago, and it took a little over an hour to complete. Disassembly was aided by the fact that the old plastic one fell to pieces once the screws were removed. Be careful when positioning the new one that you don't unplug any of the wires on the instrument lights. I did not remove the instrument cluster when I did the swap. Otherwise, pretty straight forward install and a significant upgrade.
Angus
Angus
Old May 4th, 2014, 05:55 PM
bneri's Avatar
bneri
Thanks guys, much appreciated…so I take it you guys only needed to disconnect the speedo, but nothing else? Don't really want to disconnect anything if I don't have to.
Old May 4th, 2014, 06:13 PM
El Solis's Avatar
El Solis
Chris Solis
You don't have to disconnect the speedo but it makes life so much easier
ac
Steel binnacle mount from Raptor Engineering egor Misc. Chit-Chat 7 July 20th, 2012 10:02 AM
WTB: RHD Binnacle and Cowl texrover Wanted 0 July 9th, 2012 02:12 PM
dash binnacle Best4x4 For Sale - Parts 8 June 12th, 2010 10:27 AM
LHD Instrument Binnacle newfD90 Wanted 7 September 3rd, 2009 01:27 PM
My Binnacle is broken, you know on your dash. FlaD90 Defender Technical Discussions 11 January 13th, 2009 03:13 PM
