Bimini... - Defender Source
Old July 13th, 2004, 07:30 PM
mlw911
Michael Walter
1995 D90 ST
Bimini...
Installing the bimini top for the 1st time with my new truck. Where do you attach the straps the run out the back of the top?
Tks - Michael
Old July 13th, 2004, 08:32 PM
You need to mount 2 little brackets on the back of the body tub. The straps go thru them and pull tight the top.
Old July 13th, 2004, 08:38 PM
mlw911
Michael Walter
1995 D90 ST
Are these the 2 plastic brackets on either side of the rear door on the top of the sill? They don't seem overly strong.
Michael
Old July 13th, 2004, 11:06 PM
No, they are metal brackets that are screwed in with sheet metal screws. If your top is new it should have come with the two little stap brackets and 4 screws.
Old July 13th, 2004, 11:43 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
Or you can simply run the straps down behind the seats, under the internal roll bar, back up under the seat belt, and attach to the snap above the sliding window of each door.
Did that make sense?
Give it a try.
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old July 14th, 2004, 07:29 AM
mlw911
Michael Walter
1995 D90 ST
I was also thinking of just removing my rear seat and attaching to the brackets that lock the rear seat in place. Thanks all - Michael
Old July 14th, 2004, 07:55 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Michael, just an fyi... Be sure that the Bimini is perfectly in place at the top of the windscreen before you put tight pressure on the straps. The first time I put mine on there was a small buckle where the header rail was not perfecly in the groove. When I tightened the straps I ripped a spot.
ps if you need a pic of the bracket dave is talking about let me know.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old July 14th, 2004, 11:14 AM
Nobrega
Andrew Nobrega
'94 Defender 90
I just wrapped them around the back of the cage once, then snapped them in there. They aren't tight at all, and they flap around, but so far there have been not problems as the top connect to the bar above your head anyway. It also allows for ppl to sit in the back as long as your not on the highway as the straps would knock them out.
Andrew Nobrega
Old July 14th, 2004, 12:39 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Try this (see image)!!!
You can pick get them form AceHardware, screw them in to both left & rightside of tub...
Weldon
Old July 15th, 2004, 08:20 AM
mlw911
Michael Walter
1995 D90 ST
Burke:
If you would'nt mind, that would be great. Thanks - Michael
Old July 15th, 2004, 08:51 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Here you go
ID:	1024   Click image for larger version
wanted bimini top for a 97 D90 asap bert Wanted 0 June 8th, 2005 10:48 AM
Brush Bar and Bimini Top naeirie For Sale - Parts 4 October 20th, 2004 03:28 PM
Source for Bimini top?? ronward Defender Technical Discussions 7 September 6th, 2004 05:11 PM
D-90 Bimini Top & Waterproof Seat Covers MDS Wanted 0 August 7th, 2004 07:11 PM
Bimini top & half Tonnaeu Top doozle Wanted 0 July 29th, 2004 10:59 AM
