Bilstein vs Koni - Defender Source
Old December 30th, 2011, 12:10 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Bilstein vs Koni
I have a 110 that is soft as shit. I am looking for a good on road driver. I plan on trading out the stock springs with LR heavy duty springs and changing out the shocks. I know the new springs will add an inch to the height, I don't want to raise it any more than that. Bilstein seems to be the easy choice but I like the Koni for the adjustability. Thoughts on this or other options....
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old December 30th, 2011, 12:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
I did the same thing to my 110. The genuine hd springs will give you an inch lift over stock but don't be surprised when the truck sits much higher. I am sure your truck is sagging. Mine looked like it got a 2 inch lift when I did it. I also used bilsteins and it was fine. If you look on the ecr site they use them on all their 110s so I figure if it is good enough for them.
Old December 30th, 2011, 04:21 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Bilstien hands down...last shock you'll ever buy. 100% rebuildable, can change length, valving...
Old December 30th, 2011, 07:57 PM
Does that not depend on the Bilstein model?
Old December 30th, 2011, 08:16 PM
Reese_D90's Avatar
Reese_D90
Reese
whats the Bilstein of choice??
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
ok, your right, but if your looking at a Koni shock, the comparable model to that is a Bilstien 7100. The 5100 series shocks are valved to light fro a Land Rover, even a 90. Price wise, the 7100's are only 25 buck more than the Koni's listed for 90's...
Old December 30th, 2011, 08:44 PM
Do they ha e heim joints or work with the stock mouth ts
Old December 30th, 2011, 08:50 PM
ok, your right, but if your looking at a Koni shock.....
There are a lot of Koni shocks as well, all very different.
Just saying Bilstein versus Koni can get very misleading. You need to look at individual models.
The 5100/7100 are not the "normal" Bilstein shocks that Joe Bloe would buy as a direct replacement. Those would be the B4 or B6 (4600) which are not revalvable.
Old December 31st, 2011, 07:44 PM
CDeWan
Clay DeWan
5.3L beastie
bilsteins
I belive all the heavy duty Bilsteins are re-valveable but you would have to know what you want as your compression and rebound rates. They are located a stone through from my house, so I have taken a set of used Bilsteins over to their factory/warehouse to be rebuilt. They also dyno tested another manufacturers shock for me to give me the specs of those shocks in order for me to purchase a set of Heavy Duty ones and have them valved accordingly.
If you buy the heavy duty bilsteins new you get the life time warranty with them. The only problem with that is that you would have to find a replacement or not drive the vehicle when the shocks are getting rebuilt.
I have run the bilsteins on both OME and direct stock replacement springs and find them to be a great ride and will continue to purchase that product.
I have no experience with Koni.s
Old December 31st, 2011, 09:18 PM
Reese_D90's Avatar
Reese_D90
Reese
Does anyone know the part numbers for the 5100 and 7100 series Bilsteins for a stock '93 110?
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old January 1st, 2012, 12:48 AM
bjf's Avatar
bjf
barry f
94 ST #395
Just go on the shock warehouse site. It comes right up.
Old January 1st, 2012, 02:00 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Doesn't shock warehouse give a discount for d-90 members?
Old January 1st, 2012, 02:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yes call.
I just got four for 285 shipped
Old January 1st, 2012, 02:13 PM
usadventureracing's Avatar
usadventureracing
Brett
110
Do they also have the springs?
1983 ROW D110
1970 Series III (Parting out)
Old January 1st, 2012, 03:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
No I went to rn for that
Old January 1st, 2012, 03:59 PM
usadventureracing
Brett
110
What was the total price for springs from RN and shocks from shock warehouse? RN has the heavy duty kit for 599.
Also I went to shock warehouse and the did not have those shocks show up for me 83 110. They were Rancho that showed up?
1983 ROW D110
Old January 2nd, 2012, 12:07 AM
http://www.shockwarehouse.com/index....cted_year=1995
Looks like 4600 Bilsteins to me. Correct me if I'm wrong but 5100/7100 require modified mounts, do they not?
bilstein
KONI HT RAID Shocks kjva Defender Technical Discussions 22 October 26th, 2011 08:16 PM
Bilstein 7100 bushing replacement dmarchand Defender Technical Discussions 3 September 16th, 2009 04:37 PM
WTB - Bilstein Front Shocks/Steering Damper for D-90 wadaman Wanted 0 April 23rd, 2009 09:17 AM
Bilstein shocks and bushings themaxx Defender Technical Discussions 3 October 29th, 2006 04:07 PM
Rancho, OME, and Bilstein? boshea Defender Technical Discussions 6 August 28th, 2005 08:05 PM
» Defender Registry
Outland
Outland
Daisy
lmwong
Add your Defender
