Bilstein Steering Dampner - Page 2 - Defender Source
Old June 22nd, 2009, 11:13 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by SPIKE
Live and learn.
Bilstein says the dampner is not adjustable to length but you can drill and install a schrader valve to lessen the pressure. Apparently in the past they used to use more pressure but lower it due to complaints.
My truck has about 30K original miles so it does not have a lot of slop in the front end. The tires are original and have never been rebalanced, bushings are original, etc. which no doubt could be part of the issue
This totally sux do now I need to return the dampner.
I will go with OEM or more likely OME.
Honestly,
I would just go get the cheapest 50/50 shock you can find. These things are all equal.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
bilstein
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Bilstein steering damper JFD Defender Technical Discussions 0 August 14th, 2006 08:55 AM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
Loose steering kellymoe Defender Technical Discussions 2 October 15th, 2004 08:42 PM
