Bilstein Shock Length - Defender Source
Old July 29th, 2010, 03:52 AM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
Question Bilstein Shock Length
Am getting ready for new rear shock and am interested in the Bilstein 7100 series as I've heard good things about them. They come in 8, 10, 12, 14in travel and I am wondering what the longest I can fit with a 1 1/2 in lift? Figured try and get a little extra travel when I put the new shocks on.
Old July 29th, 2010, 01:08 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
travel and lift are not directly related to each other... you will need new towers with whatever you go with as the connections are different. Where and how you fit said towers will effect your need for different bump-stops to keep from bottoming out on your shocks. Additionally... you may need cones for your rear springs as you might droop past thier length with increased travel...
Old July 29th, 2010, 04:15 PM
Defender90_218
Trenton Smith
1997 D90
The mention of the lift was just to make clear the only suspenion adjustment, I actually dont want anymore lift just travel.
A guess a better question would be has anyone mounted 7100s and how did you do it? Also can you order them with different mounts?
Old July 29th, 2010, 04:17 PM
I ran 10in shocks with ~2in of lift and rockware upper mounts.
bilstein
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Static rear shock length? KevinNY Defender Technical Discussions 1 February 7th, 2008 06:04 AM
Bilstein 7100 shock pair $300.00 brn24whl For Sale - Parts 5 April 21st, 2007 09:18 AM
Shock length flippedrover Defender Technical Discussions 3 June 6th, 2004 12:20 AM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
