Bilstein shock failures - Defender Source
Join the Defender Source Community Today
Old August 10th, 2016, 04:17 AM
Just an FYI for those looking to buy bilstein shocks.
The top sheared off mine probably not helped by running 2inch lower shock mounts. The shocks were only a couple of months old.
Jimmy sheared the top off and the rod punctured his tub.
The warranty response from bilstein was non-existent.
Seems to be a common failure.
Old August 10th, 2016, 04:36 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
7100?
Old August 10th, 2016, 06:16 AM
rovertrader's Avatar
rovertrader
Dale
Fish Taco 90, 109 Coiler S/T 5-door
Had the same issue on OME once, but they were very responsive and overnighted replacement to Moab.
Old August 10th, 2016, 06:27 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Had it happen to an OME twice, once on my truck and once on a friends truck, Ome replaced the shocks very quickly.
Land Rover 110
Old August 10th, 2016, 06:39 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
My only issue has been their crap bushings that seem to compress and rattle around after a few years. I had one fail probably due to my bump stops not being a proper size. I agree, I called to discuss and they were defensive off the bat. When new they're great though. Nothing beats that feeling of new shocks, springs and tires combo.
Old August 10th, 2016, 07:13 AM
You added 2" lower top mounts. Did you add 2" longer bumpstops? Did you cycle the suspension without the spring in place to check whether there was actually room for the shock to compress fully without bottoming out?
Seams to be a common failure.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 10th, 2016, 07:26 AM
We need to know the full story here!
Old August 10th, 2016, 07:37 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I have had three ome's fail in the same fashion. I welded the top hat back on and put the shock back on. When re-installed i tightened the nut down until the washer contacted the bushing rather then completely down to the shoulder on the mount. Haven't had an issue in 2.5 years!
Ryan
84 110SW County LHD
07 L322 Vogue
Old August 10th, 2016, 08:01 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I had an old Bilstein break; I'm pretty sure I was with you on Big Levels trail when it happened!
It was a rear on the Hunter, right at the top/loop.
I welded it back together the next day and it lasted several more years.
Originally Posted by Ren Ching View Post
You added 2" lower top mounts. Did you add 2" longer bumpstops? ?
When mine broke, it was essentially a stock height truck.
When I put any lift on, I use some 1.5x3" box steel and weld it to the bumpstops to add the correct length.
Rent my
Old August 10th, 2016, 09:10 AM
Mine has mount extensions on the lower portion of the shock mount and I also have extended bump stops. I'm pretty sure the shock were stock length and I also had taller springs fitted. Jason is referring to the cheaper yellow Bilsteins, not 7100s. I swapped all of my stuff out for OME.
Old August 10th, 2016, 11:24 AM
pics of the shocks puncturing through your tub?
That's crazy...
Old August 10th, 2016, 11:56 AM
That's crazy...
I'll try to take one tonight. Its more of a dent with a slight tear. I'm just going to put some sealant over it to prevent water ingress.
Old August 10th, 2016, 12:18 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Bilstein failures you say???
Old August 10th, 2016, 12:22 PM
4x400 meter Bilstein relay event baton handoff?
Old August 10th, 2016, 12:27 PM
no way, man! wear that badge of honor
Old August 10th, 2016, 01:12 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I went to have my 7100s revalved and after days and days of trying to get ahold of someone at Bilstein in southern Cali, somebody finally called me back. I asked what the deal was and he told me that Bilstein off road in the US is basically 2 guys in the back of a warehouse in SOcal. All of their support goes to their road racing products. Off road is an after thought in this market, which is weird to me. Might have changed in the past 2 years but I switched to Fox and like them much better. Not to mention they revlave for free in the first 90 days or whatever and their customer support is great.
Old August 10th, 2016, 01:16 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I just replaced two 7100's for 0psi. Have not had a chance yet to take them apart to rebuild and determine the cause. But will.
Old August 10th, 2016, 01:47 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Remote Res? I wouldn't bother next time around, they all bleed down for whatever reason. I was loosing 50 PSI per shock a year. Basically when the snow would melt, I'd pull them all off and take it to a motorcycle/mtn bike shop and have them fill it with nitrogen.
Old August 10th, 2016, 02:01 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
never a issue with the 7100's...Eshocks.com is your friend, they have all the parts, normally in stock.
loosing pressure is normally the schrader valve. Remote res is a little blingy, but if you carry a ton of shit, they do make a difference because they are less likely to fade on long runs
ini88's Avatar
ini88
Daniel Marcello
1994 Defender 90 #916
My 7100 broke but I did something stupid to break it
1955 Series I
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Lift Pump Failures? Shagey71 Defender Technical Discussions 23 August 29th, 2016 12:41 PM
3.9 Fuel Pump Relay internittent failures djrover Defender Technical Discussions 0 September 3rd, 2013 11:47 AM
Bilstein Shock Length Defender90_218 Defender Technical Discussions 3 July 29th, 2010 03:17 PM
Fox/Bilstein shock questions d90dan Defender Technical Discussions 3 September 19th, 2009 12:21 PM
Bilstein 7100 shock pair $300.00 brn24whl For Sale - Parts 5 April 21st, 2007 08:18 AM
