Bilstein shock failures - Page 2 - Defender Source
Old August 12th, 2016, 05:17 PM
cbfritz_03
Carmen
none
I just got my set of 7100s...fingers crossed
Car Camping Collective founding member - Badge #88 ...with 4 whole fried chickens and a coke.
Old August 12th, 2016, 05:29 PM
Back many decades ago, we saw this happening and determined that it was due to bushings being overcontained. The shocks when run out of angular movement and then snap the attachment. The bottoms on, I think the later Disco 1s had bushing cups on the bottom that were welded to the support and with some shocks, would not work with the bushing. The Bilsteins, in particular, would not work with them and you needed to cut the cups off. When you install, test each and and make sure that the shock can easily move enough.
Old August 12th, 2016, 06:17 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Improperly installing the cupped washers can snap your eye/shaft off
Love my 7100s.
Old August 13th, 2016, 09:06 PM
cbfritz_03
Carmen
none
oh..I think I know what you're talking about. Those little cups...I used a chisel, a hammer and some vise grips to peel those off and out of the way.
Lift Pump Failures? Shagey71 Defender Technical Discussions 23 August 29th, 2016 12:41 PM
3.9 Fuel Pump Relay internittent failures djrover Defender Technical Discussions 0 September 3rd, 2013 11:47 AM
Bilstein Shock Length Defender90_218 Defender Technical Discussions 3 July 29th, 2010 03:17 PM
Fox/Bilstein shock questions d90dan Defender Technical Discussions 3 September 19th, 2009 12:21 PM
Bilstein 7100 shock pair $300.00 brn24whl For Sale - Parts 5 April 21st, 2007 08:18 AM
