Bilstein Install Question - Defender Source
Old September 16th, 2006, 07:18 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Installed bilsteins on the '97 D90 this weekend and have a question. On the rear lower mounts, are the oem cups that retain the rubber bushings supposed to come off. There is one on the top and one underneath on each side. The new shocks came with new washers but it looks like the ones on there are tack welded on. I hammered on them a bit but they did not move. Picture attached....thanks guys
jeff
Old September 16th, 2006, 07:30 PM
Yes, remove those cups that are (lightly) attached to the shock mounts. You WILL break your shocks otherwise.
Old September 16th, 2006, 07:57 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Does that mean those cups ARE welded on to the mount flange??
j
Old September 16th, 2006, 09:02 PM
A small spot weld.
Old September 16th, 2006, 09:17 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Thanks guys. I knew there that air chisel would come in handy one day.
j
Old September 18th, 2006, 12:00 PM
tron's Avatar
tron
Thomas F
Recently Roverless
Which part is John suggesting you knock off? Is the pen pointing to a rubber bushing or a metal cap?
Old September 18th, 2006, 12:21 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yes, knock that pen off, too. There is no pen attached to mine--it looks like it is being held on by just the tip. ;-)
Old September 18th, 2006, 04:08 PM
tron's Avatar
tron
Thomas F
Recently Roverless
That's a good one. Anyway...is that a rubber bushing or a metal cap?
bilstein
Gas Tank Skid plate install on a D90 - question... pmd Defender Technical Discussions 17 December 19th, 2011 04:04 PM
Fiberglass top install question d90_1372 Defender Technical Discussions 7 September 14th, 2009 11:07 PM
header install question JBOD77 Defender Technical Discussions 1 August 28th, 2009 10:53 AM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
