Bilstein install question - Defender Source
Old September 20th, 2010, 12:58 AM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
I am installing new bilstein shocks in the rear. I noticed that the upper rubber shock mounts included with the shocks don't have a metal sleeve that runs through the two bushings. Should there be a sleeve running through it? The upper factory shock bushings did have a metal sleeve through the middle. The bushings included with the Bilsteins seem to fit snuggly on the shock mount so it dosen't seem there is room for a sleeve. Can someone help me out?
Old September 20th, 2010, 01:21 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
No sleeve on the old man emus. If it is snug, ill bet you are fine.
bilstein
Gas Tank Skid plate install on a D90 - question... pmd Defender Technical Discussions 17 December 19th, 2011 04:04 PM
Fiberglass top install question d90_1372 Defender Technical Discussions 7 September 14th, 2009 11:07 PM
Bilstein Install Question 48vphantom Defender Technical Discussions 7 September 18th, 2006 04:08 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
