Bilstein Damper Still an Issue - Defender Source
Old January 19th, 2018, 03:22 PM
MiamiDefender
Christian
1991 Defender 110
Is it still true that the Bilstein damper is pre-loaded and too aggressive?
Old January 19th, 2018, 03:40 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Shocks or steering damper?
Old January 19th, 2018, 03:43 PM
Naplm00
Matthew
I run a spring loaded return to center steering damper, works fine. I can't imagine the bilstien is remotely as strong
Old January 19th, 2018, 07:05 PM
MiamiDefender
Christian
1991 Defender 110
Steering
Old January 19th, 2018, 07:21 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
any non-pressurized shock will work, I use OME. really there is no need for one as more times one is masking a steering/suspension fault.
Return to centre spring??
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 19th, 2018, 07:36 PM
ruggedalaskaman's Avatar
ruggedalaskaman
Frank
1995 NAS D-90 #375
When ECR put Bilseins shocks on my NAS 90 the said the Bilstein steering stabilizer didn't work well on the Defender and used an OME. I didn't get the details of why that was.
Old January 19th, 2018, 07:45 PM
Really. Just use a stock one. There is nothing to be gained by spending more.
Old January 19th, 2018, 07:48 PM
Naplm00
Matthew
https://goo.gl/images/G1hkyE
Some people really dislike them, and yes they can mask an issue. My truck is nearly 100% new from the axle tube flange out... This damper definitely helps move my 35s back to center. When I go higher and replace my radius arms I probably won't need it anymore. At this point I'm at about 1 degree negative caster but it's very tolerable.
I'd say for a stock or close to it truck anything would work well. I just installed a ome from a local friend and it went in smoothly and works great!
Old January 19th, 2018, 07:57 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
We've sold 304 since 2012, 4 have been returned. 3 of them were not needed, the other was "part not as expected". That could mean the person didn't like it, it's hard to say.
Old January 19th, 2018, 08:05 PM
MiamiDefender
Christian
1991 Defender 110
I heard from Scott today that the Terrafirma might even be a better option. Thoughts?
Old January 19th, 2018, 08:18 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
The TF was fine, I used it on my D2 and my D1 with no issues. I'm running an Old man emu unit now and it works as well.
Old January 20th, 2018, 10:41 AM
I still have no idea how anyone objectively evaluates a steering damper as "best" when the stock damper is 150% adequate.
You might as well just buy it based on the color of the damper body and the stickers.
Old January 20th, 2018, 10:51 AM
Aftermarket one just make it harder to steer. They are not an improvement in any way.
bilstein
WTB - Bilstein Front Shocks/Steering Damper for D-90 wadaman Wanted 0 April 23rd, 2009 09:17 AM
Bilstein steering damper JFD Defender Technical Discussions 0 August 14th, 2006 08:55 AM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
Questions regarding Steering damper Mark M Defender Technical Discussions 2 November 20th, 2004 02:45 AM
