Bilstein 7100 valving question - Defender Source
Old June 18th, 2013, 12:15 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I have 7100 non-remote res shocks on the 110. I went for 360/80 valving all around thinking that would be good since I do not run the truck loaded down all the time. The front is good by the back is not. Truck is kinds loosey goosey and off road I am hitting bump stops. So I feel I need stiffer valving in the rear. Thinking of going to 400/100 but then was reading how adjusting the nitrogen pressure can also improve dampening.
So anyone have experience with this? Should I revalve or try the pressure route? If so on the pressure route what should it be to improve and stiffen up the rear?
Old June 18th, 2013, 12:50 AM
You running a rear sway? How about the rear BOGE load leveler?
Old June 18th, 2013, 01:03 AM
Hitting the rear bump stops???
How on earth do you do that? Desert racing???
Old June 18th, 2013, 02:43 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
You need to check the pressure first, they may just be low.
Old June 18th, 2013, 10:18 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I am hitting the bump stops at times as I have longer ones to limit the up travel and not bottom out the shocks. But this only happens on higher speed larger bumps like big speed humps going faster.
I will check out the pressure. So is it best to just take them to a racing or motorcycle shop that deals with charging shocks?
Thanks for the help.
Old June 20th, 2013, 09:17 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a boge if interested as well
Legend in My Own Mind.
bilstein
Bilstein 7100 shocks crown14 For Sale - Parts 2 November 15th, 2012 09:56 AM
Bilstein 7100 shock travel question Tyler Wirken Defender Technical Discussions 6 August 5th, 2012 02:06 PM
12" Bilstein 7100 Shane@EVS For Sale - Parts 4 June 21st, 2011 12:02 PM
Bilstein 7100 bushing replacement dmarchand Defender Technical Discussions 3 September 16th, 2009 04:37 PM
Bilstein 7100 Valving ini88 Defender Technical Discussions 5 July 26th, 2007 01:29 PM
