Bilstein 7100 bushing replacement - Defender Source
Old September 16th, 2009, 08:14 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I'm getting some noise from my rear shocks and am pretty sure the bushings are shot as their is a lot of play on both. Has anyone changed the bilstein 7100 bushings to daystar or equivalent?
I found this info for replacement on a google search and want to make sure it is correct.
Those heim joints on the 7100s wear out super fast. I went through a bunch of the heims before I replaced them with a poly replacement. They lose a little twist, but the poly sure does ride a lot nicer. If you need the part# let me know and Iíll dig up my notes. I bought them from Paul at eShocks.com I bought mine from eShocks: (800) 303-6211 Talk to: Paul - Bilstein rep Ask for Prothane 19-920 (12mm bolt) or (19-919 1/2″ bolt) - Bilstein 7100 heim joint replacement bushings You need 4 packages as each package comes with 2 bushings (top and bottom). Total will be around $45 I bought 19-919 because I bought my 7100s before RTE started selling the step down spacers to use with the factory Land Rover bolt size. If you drilled/tapped your shock mounts for 1/2″ bolts you want the 19-919. If you are running the genuine bolts with the RTE step-down spacers you want 19-920. I believe both part numbers have an extension that describes the color (e.g. 19-919-BL for black).
How easy is the bushing press out? Just trying to decide if my press will handle it.
Old September 16th, 2009, 08:31 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I changed mine to the poly bushings and it is easy to crank the out ones out. I think we used a vise with some sockets. one to push one to receive. so if you have a press it should be no problem. You will get a loud bang then you know the heim is out.
It will cut all the noise out. i've been running mine for 1.5 years and they are still fine.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 16th, 2009, 08:51 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I think Alan at Cityside stocks them now. Berg had them put in my old D2 at Alan's.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old September 16th, 2009, 04:37 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Thanks guys, talked to Alan. Ordered them from eshocks. I'll pop them out and do a quick write-up.
ac, bilstein
Panhard Rod Bushing Replacement cellulararrest Defender Technical Discussions 2 August 24th, 2007 10:48 PM
Bilstein 7100 Valving ini88 Defender Technical Discussions 5 July 26th, 2007 01:29 PM
Bilstein 7100 shock pair $300.00 brn24whl For Sale - Parts 5 April 21st, 2007 09:18 AM
Bilstein 7100 billet resevoir clamps - new (2) dmarchand For Sale - Parts 2 August 30th, 2006 04:03 PM
rancho bushing replacement? jorge Defender Technical Discussions 6 April 7th, 2005 03:36 PM
