Bikini Top - Defender Source
Old August 31st, 2008, 08:24 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Bikini Top
I have a Bestop bikin top and want to know how to attach it.
I know the gutter part on the front and the snaps above the doors, but I have straps and I think it should have two brackets at the body tub that the staps go through.
Question is does anyone know what size/length bolts I need to attach the brackets? I need the brackets too but I am thinking I can just get these parts at ACE. The body tub has the holes and they are already threaded, I just don't know the size.
Alex
Old August 31st, 2008, 09:49 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
I never used the brackets on mine. It's been a while but I recall the strap was long enough to run down under the roll cage tubing (behind the front seats) and back up to snap onto the bars above the windows. It worked well this way for 5 summers.
Regards,
Art Vigil
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old August 31st, 2008, 10:22 PM
themaxx's Avatar
themaxx
Ade
94 ST
I wasn't a fan of the strap style bikini top. When I had it, I just tied it off at the C pillar. I personally would modify the top with the necessary snaps to attach onto the B pillar instead of drilling holes into the tub.
The best option is to buy a Badger strapless bikini.
Old September 12th, 2008, 12:45 PM
specops1526's Avatar
specops1526
Beluga '97 90
Those bikini tops came with C-clamps that were to be screwed into the cappings on either side of the rear door. I think you can remove the brackets that hold the rear window bar in place and screw the brackets into those existing holes. If you don't have the brackets, I'm sure you can fab something simple up from stuff at Home Depot.
I agree with getting the strapless one from Badger though. It's doesn't provide much protection from the sun on the back of your neck but it's less hassle with those straps going thru the back of the truck.
If I were you, I'd just run a surrey top, much better in my opinion. Once I got mine, I've never gone back to the bikini top.
Old September 12th, 2008, 03:17 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Don't use the brackets. They are just more holes you don't need to be putting in your truck. I ran the straps to the C or D pillar. just wrap them around there, so later down the line when its winter and you have a hard top on it you don't have stupid brackets in the back and you ask yourself "WTF? why did i do that?"
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 7th, 2009, 10:12 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
Bestop Bikini Snaps?
I've had a Bestop bikini top since new but have never used it... I have the header bar for the front but the canvas top has snaps on the side also.. what do they snap on to?
1994 D90 #1880
Old September 7th, 2009, 10:28 PM
The five (or 5) snap door bars.
The things in the back are called footman (or footmen) loops.
Old September 8th, 2009, 06:36 AM
mikeybob2@msn.com
Michael Sabanovich
Thanks! I appreciate the help.. I see Roverconnection has them for $120.... Thanks again....
1994 D90 #1880
Old September 8th, 2009, 09:11 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
On the 94 D90 the strap snapped into snaps on the back side of the tub. Then rover put a "tie down staple" on top of the tub rail - the strap went thru that and snapped onto itself. If you have threaded holes six inches inboard of the tube side then you probably have the latter style. The tie down staples are available from RN and the bolt size is probably 5 mm.
bikini top
Bikini Top Or Crappy Surry Top NashvilleRedD90 Wanted 18 May 31st, 2006 11:15 PM
Badger Coachworks Bikini Top danielj For Sale - Parts 6 August 7th, 2005 04:24 PM
Defender Bikini top & things.... tbmcneill For Sale - Parts 0 February 2nd, 2004 05:33 PM
factory bikini top 4 sale aschoent For Sale - Parts 0 December 26th, 2003 07:37 PM
Bikini Top ron For Sale - Parts 7 November 20th, 2003 06:23 PM
