Bigger engines - Defender Source
Old January 10th, 2016, 11:53 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Bigger engines
Anybody have any experiences with bigger displacement engines that are, still in the Rover family? Like a 4.8, 5.0, 5.2 from some of the UK Rover engine builders? We're trying to figure the best options for a d1 with manual trans, an interest in keeping it stock appearing, and not fragile or requiring premium.
Email is
Same place, new dogs.
Old January 10th, 2016, 11:55 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Damn Trevor, the 4.6 was too much displacement already for that aged block design, 5.2??!
Old January 10th, 2016, 12:29 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I would stay away from any variant of the old Buick 215 (3.5, 3.9, 4.0, 4.2, 4.6).
I hear good options are 5.0 Ford or GM LS3.
Anyone know what transmission options have worked best?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old January 10th, 2016, 10:45 PM
Frank84
Frank Battersby
95 D90
Just my opinion, but I wouldn't go past the 94mm bore of the 4.0/4.6 - the walls are too thin already! The 4.8 keeps this and just adds a longer stroke. The 5.0 bores it out to 96mm which sounds like a bad idea. Not sure on the 5.2
Keep in mind the R380 was originally only meant for a max of 380 Nm (280 ft lb) of torque so that may become your weak link. From Ashcroft's site, it sounds like you'd want a suffix L box from a post '99 vehicle for the best strength - assuming you can get a V8 version.
'95 Soft Top
'89 Classic Tdi
Old January 10th, 2016, 10:49 PM
I think Drew built Will Tillery a 5.0 or 5.2 for the 130 that vanished. You further stroke a 4.6
Old January 11th, 2016, 12:19 AM
http://store.toddcosuspensions.com/landrover50ho.html
Old January 12th, 2016, 08:39 PM
RSAmerica
David Katz
1985 Defender 110 SW County
I put ACR 4.8 Hi-Torque in my 110. Great motor!..
Old January 13th, 2016, 07:41 AM
Roverlab
Trevor Griffiths
David, I was going to reach out to you as well to see how things are going. I take it the Rover is back together and running well? Did you carb or fuel inject?
Email is
Old January 13th, 2016, 08:58 AM
RSAmerica
David Katz
I have ~2500 miles on the ACR 4.8 Hi-Torque, it's running great! It makes lots of low end torque. I am running a Edelbrock carburetor. ACR says it would make more power at higher rpm with EFI. The bottom end is good to 6,000 RPM per ACR. I highly recommend ACR.
I need to replace the shoot LT95 4 speed. The gearing is way to short on the highway. With the 4.8 you can start out in 2nd gear. Down the road I want to put in a rebuilt R380 5sp with a LT230 1.2.
engine
Bigger radiator on a 4.6 JFD Defender Technical Discussions 3 November 3rd, 2011 09:23 AM
more powerful power steering pump and a bigger reservoir cdb Defender Technical Discussions 10 June 14th, 2010 11:16 PM
bigger sway bar for rear CDeWan Wanted 0 May 15th, 2009 07:14 PM
for when you change to bigger tires 1000kva Misc. Chit-Chat 1 September 24th, 2007 08:19 AM
bigger RIM's rover4x4 Misc. Chit-Chat 25 March 10th, 2005 10:06 PM
