BIG PROBLEMS - Drive train/Trans - Defender Source
Old May 5th, 2015, 09:18 AM
minch77's Avatar
minch77
Minch
1997/Defender 90 SW
Unhappy BIG PROBLEMS - Drive train/Trans
There are two parts to this matter:
1. While wrestling with one issue for which I had gotten advice on the forum, a clunking noise coming from the front left wheel that cropped up after my mechanic/friend replaced my rotors, pads, calipers, I followed forum advice and eliminated steering ball joint, suspension, etc. I was convinced it had something to do with how they refitted the inner axel and hardware after removing it for the brake job. The noise corresponded to the rotation of the tire at 360 degrees. It was silent when driving straight--as soon the D-90 shifted weight for a turn I would hear it. Again, it clunked as the tire rotated and with each full rotation while turning. Could it be related to the brakes? Before you answer, here is the next BIG problem.
2. I drove it a block and was slowly making 360 degree turns in a gravel parking lot trying to focus on the clunk. It seemed to get louder with each rotation while turning tightly. BANG! While slowly driving in circles a loud bang followed by what sounded like spinning gears grinding occurred. Despite being in drive it would not drive. I engaged the 4 wheel and limped it 2 blocks home. During that slow ride home at 5 mph, metal banging from underneath would randomly come and go. Of course when finally turning into the driveway there were all sorts of metal noises but I gingerly made it back to the drive way.
Where do I begin figuring out what is busted? Is it the gear box? the rear differential? The propeller? Can the inner front axle had a part in this? Perhaps the two problems are exclusive of each other and I just had a rotten day? The universal is intact as I can see and nothing is hanging out from the bottom.
When the noise occurred it sounded/felt as if something was dragging on the ground but when I looked there was nothing there. Also, the front drive shaft spins back and forth a little bit hen I crawl underneath and start twisting it with my hands. The rear drive shaft seems locked in place and won't give. Maybe that is normal?
Old May 5th, 2015, 09:31 AM
87 D110 (Ruby)
First it sounded like CV joints....and Axles - be my first guess what broke
Old May 5th, 2015, 09:41 AM
the rover shop
shayne young
With the truck on level ground and no park brake applied, make sure the truck is out of diff lock..transfer lever to the right.. If you can spin the front driveshaft then your problem is in the front axle.. As Jonesy says.. Sounds like front axle/cv joint..
Old May 5th, 2015, 09:46 AM
minch77's Avatar
minch77
Minch
1997/Defender 90 SW
Thanks for giving me a starting point. Here is a follow up question: If the CV joint or front axle was the issue would the front wheel drive still work? How does the front axel end up knocking out the power being sent to the rear drive? I apologize in advance if that is a stupid question but I am limited in my understanding of the transmission/drive train system.
Old May 5th, 2015, 09:51 AM
the rover shop
shayne young
Unless diff lock is engaged it allows the front differential to do its job and doesn't distribute power to both of the wheels because it has no force to react against on the side it is broken on..
Old May 5th, 2015, 09:57 AM
popped a cv, but something weird about that.
do you have front lockers?
Old May 5th, 2015, 10:15 AM
minch77's Avatar
minch77
Minch
1997/Defender 90 SW
Yes I have arb air lockers front and back. They were not engaged on the day I lost power.
I had been under the assumption that when I locked the diff I was limping home using the power from the front wheels---I thought the rear axle lost the power. You guys have me changing that up. I just went outside, put it in lock and went 10 feet back and forth in the driveway. If it's locked I can move. How can I confirm that the rear axle is still getting power and not just spinning because the rear wheels are turning?
Old May 5th, 2015, 10:23 AM
See above...
You have a broken CV joint. Do not continue to drive the truck. The broken joint will continue to destroy more parts and it could cause your steering to lock up and kill you.
My "guess". The mechanic forgot to install the circlip on the stub shaft of the CV joint and it moved in an jambed up. That, or it is just a strange coincidence the joint died right after the brake job. You need to get the truck inspected and worked on by another party that knows what they are looking at. Use a tow truck to get it there.
Old May 5th, 2015, 11:08 AM
sounds to me like the front diff was possibly locked. you'll find out when you see what broke.
Old May 5th, 2015, 11:19 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Had a vehicle come in with a similar issue.
Was able to jack it up to where both front wheels were off the ground.
Then removed some plugs... don't remember exactly which ones, but think it was the diff filler plug.
Had someone spin one wheel at a time.
Looking through the "hole" left when the plug was removed, I was able to see which shaft was spinning and which shaft was not.
The side that was not spinning was disassembled and the actual shaft found broken.
A whole shaft CV and all was pulled from a low mileage Disco I and installed in the broken 110.
That was more than 5 years ago and the vehicle is still being driven daily.
Easy fix.
You could also have a broken spider gear, but you should see it through the hole with a small flashlight.
RDavisinVA
Old May 5th, 2015, 12:01 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
IF you have a front ARB, you could jack the front end up. Then put it in gear, lock the center diff, turn the front ARB on and see which wheel turns or doesn't turn. Or which one makes horrific noises. The sounds you mention sound like what I've heard when I've blown a CV joint apart.
Old May 5th, 2015, 12:08 PM
Doubt that it had anything to do with a locked differential. I've driven on the hard with diffs locked and it is near impossible to turn the steering wheel; tires chirping, scrubbing etc. I.e., you would have known something was up.
As others have said, it's most likely a CV but possibly in the differential itself. But, ARB lockers use a 4 pinion carrier that is unlikely to break the way a stock open diff often does. That said, you can and should drain the differential and see what comes out. Ditto the swivel housings.
Since you have ARB lockers, you can use them to figure out which side of the axle is broken. With the ARB locker engaged, raise each wheel individually and try to turn it. If it turns, that is the side that's broken.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 6th, 2015, 04:16 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Sounds exactly like when I broke my Pass side CV in my D1 after Conclave a few years ago. I agree with the crowd, broken CV is most likely.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old May 7th, 2015, 04:59 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I think an important question would be what did his mechanic/friend reassemble incorrectly that could lead to a blown CV? Would not replacing the c-clip on the end of the CV cause a failure like this?
Old May 7th, 2015, 05:11 PM
The OP needs to pull the CV and inspect it. All we can do is guess.
Old May 9th, 2015, 08:26 AM
minch77's Avatar
minch77
Minch
1997/Defender 90 SW
CV JOINT IT IS! I jacked it up and spun the wheel by hand. Driver's side was quiet when being turned. When I turned the passenger side wheel I immediately heard the bits and pieces rolling around. The case holding the bearings was in pieces and came out along with free floating bearings.
Now my questions are: I am poised to buy a new CV joint. Are there any other parts near it that I should also replace as a good measure? Also, I have a 1997 NAS so when I shop for parts, even though it says it fits a 1997 D-90, it doesn't fit. Can anyone tell me the correct part number for 1997 NAS CV Joint? Or are they universal for all models?
Old May 9th, 2015, 08:51 AM
87 D110 (Ruby)
here is one that works - not genuine, but - CV JOINT DISCOVERY DEFENDER 90 - DISCO I, PLD201, TDJ000010 - Rovers North - Classic Land Rover Parts
Old May 9th, 2015, 09:25 AM
the rover shop
shayne young
And Jonesy to the bloody rescue again....
Old May 9th, 2015, 10:57 AM
Chalk this up to Rare failure syndrome.
Old June 1st, 2015, 04:42 PM
minch77's Avatar
minch77
Minch
1997/Defender 90 SW
Red face The Fun Continues...
Since the last post I had the CV joint, half axle, and stub axle on the front passenger side changed. It was all assembled at my friend's shop--not land rover guys--(please excuse this stupidity momentarily while I finish this) and when I took it for a spin I immediately noticed the following:
1. A "whirring" noise is apparent when I hit the gas
2. It felt as if the trans was in a lower gear and the whirring noise got louder as the speed increased
3. when i let off the gas the whirring noise immediately went away and remained so as I coasted down the street
4. As soon as I applied the gas the whirring noise reappeared immediately--it corresponded to applying the gas
5. I can feel a corresponding vibration as I grip the diff shifter
6. It feels as though there is resistance when I apply the gas but not when I coast along
Background: When I blew up the CV joint at slow speed I limped it down the street to my residence where I had it towed to the shop. During my 3 - 5 mph drive home I didn't hear any such "whirring" noise.
Question: With all new parts, is there anything here that sounds like they botched the installation of the new parts? Is it possible they tightened the hub nuts too tight? (Sorry if that is stupid) It just feels as though something is too tight or bound up in the axle.
Next Question: I am sure there is a Defender guy in New Jersey and I will search the forums but if anyone knows right off the bat I would appreciate it. I am tired of dealing with things half-assed and need to get a pro--I just don't want to bring it to an overpriced LR dealer who will extort me.
problems
Bad Zula Engine and Drive Train Bill Larson Defender Technical Discussions 20 February 14th, 2014 12:21 PM
Looking for a Disco 1 with great drive train Uncle Douglas Wanted 3 February 18th, 2010 09:31 AM
Rolling chassis with drive train $1000 bitz The Flea Market 0 August 12th, 2009 08:48 AM
oil leak(s) coming from my drive train michael15 Defender Technical Discussions 24 September 15th, 2005 10:28 AM
drive train custom mods redrover Misc. Chit-Chat 14 June 11th, 2004 09:08 AM
