Bias Ply vs Radial Tires - toughness? - Defender Source
Old February 27th, 2012, 05:49 PM
Warning, ignorant newbieness ahead:
So long story short, my Defender with street tires did pretty well at Rausch Creek considering it had 29.5" All-Terrains. The tires were Kumho KL78's which have a 2-ply sidewall.
But after a short trip on a freshly cleared trail - just barely a green - something (either a sharp rock or a chainsawed stump) tore a hole in my sidewall like it was toilet paper. Thanks to Charles, Jeff, Jason, Doug and some other OCC folks, the spare went on (though me being a total idiot, the spare was bald, dry-rotted and leaking air.) Following Jeff, I got the truck home after a highway blowout, a surprise visit from RayG + friend, and a AAA flatbed tow. Fun fun.
I originally got smaller tires because I wanted a tight turning radius without rub and the ability to fit into ridiculously low USG parking garages, but now I'm leaning toward saying "screw it" and going with something that won't behave like American Cheese on the trails.
I understand that some radial tires are pretty tough (KM2s, Interco's trXus MT), but it seems like bias ply tires are generally tougher.
Here's the question - should I even bother with a radial tire when I could buy a bias ply tire instead - just from the perspective of sidewall toughness? I can live with not making up a trail, but I want something that will live through wheeling.
I have a feeling that my fellow NOVA peeps will now respond with "stop being a cheapf***" and just get KM2's , but I'm still curious.
Old February 27th, 2012, 06:29 PM
Bias ply tires have their fans, but I'm not one of 'em. I just bought both the Goodyear Wrangler MT/R Kevlar for the 109 coiler and a set of Goodyear Wrangler Dura Tracs for the RRC. These are in the 235/85-16 size. Either would be a good choice for your truck.
Both the bias ply and the radial will have nylon side wall construction. However a 4 ply radial sidewall will be far more supple than a bias ply with 4 sidewall plies. They corner better, have better highway handling, give better gas mileage, etc etc. If you have a particular need for a stiff tire, try the bias ply, but I have a feeling that you won't be too happy with them.
Old February 27th, 2012, 06:41 PM
I've seen one other set of those Kuhmos no comment.
235's would be a good fit if you truck is stock, you increase your turning radius and gain a few inches of clearance. BFG Mt's have been very impressive, looking to see how the new MTR's and Duratracs perform
My Classic runs 225/75s, I bang my diffs and steering a little more than in the Defender with 255's. I wouldn't run less than a 235 on a Defender.
Old February 27th, 2012, 06:46 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Actually most Bias tires will not hold up as well on the trail as a radial trail tire will. The ability of the tire to rap around a rock etc is what you are looking for. In a tire search you will find manufactures playing with the amount of plys in the sidewalls. Most Bias have a two ply sidewall and are very stiff. A lot of the off road radials will have a three ply sidewall. In choosing a trail tire that you also use on the road keep in mind if the tire has sipping, extra cuts in each tread block. This sipping is what helps in the rain and snow giving the tire more biting edges. Off road it might be bad, destabilizing the tread block and making it easier to tear. With that said the Km2's, no sipping, still do very well on the wet roads. Also when you go off road remember to air down. this gives you a larger contact patch.
Land Rover 110
Old February 27th, 2012, 07:51 PM
front wheel spacers and adjusting your axle stops can give a tight turning radius even with large tires. I have
34x10.50x15 Tsl bias plys on Wolf/Nato/130 wheels for off road and 285.75.16 Yokohama Geolanders on alloy's for street. The geolanders suck off road and the tsl's suck on road. That said they both excel in their intended purpose. A bias ply tsl @ 10 psi is awesome offroad.
Old February 27th, 2012, 10:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
o2batsea - how do you like the MTR Kevlars? Seriously thinking of going these over KM2's in a 315 size. I'm really thinking with modern tire tech you can get a very good all around tire.
sonoronos - I think a good tire in 235 would work well like rover4x4 said. If you were happy how your truck did with the street tires and are running stock suspension I think they will be a good fit. Put on spacers or a wheel with less backspacing like a Wolf/Nato and your turing radius will be as good as a D90 can be.
I found some pics of a MTR Kevlar flexing - thinking this will show was MC22958 was talking about. Was from this thread on a Hummer board: http://www.hummerxclub.com/forum/vie...12463&p=197654
There are some threads about the MTR Kevlar haven't a stronger sidewall than the KM2 if that is of any help. I think it was on an Arizona Jeep forum.
ID:	48373   Click image for larger version
Old February 28th, 2012, 08:29 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
You should just get a different set of wheels and tires for offroading. It takes little time to change a set and then you don't have to sacrifice anything but time before you go hit a trail or go camping.
You little rebel, I like you.
Old February 28th, 2012, 09:09 AM
No kidding, mud tires wear out quick on pavement.
------ Follow up post added February 28th, 2012 09:14 AM ------
The MT/Rs are a long way from getting dirty, so I can't offer a review. The Dura Tracs are prolly a better all around tire. Compound not so soft and an almost equally aggressive tread to the MT/R. Slightly cheaper too. I will certainly try to off road on them.
Old February 28th, 2012, 10:07 AM
Ed, my advice to you based on your multi-use would be to go with a 235/85-16 (stock size, and what I have on the 110) in either a BFG A/T or BFG KM2. I think you'd be better served by the KM2 as you'll find they're surprisingly comfortable on road, but may cost a tad more.
It isn't going to be cheap, BUT you'll avoid the issues you had at Rausch this weekend. Just my $0.02.
However, it is also worth noting that Ed - and his stock D - did great with the exception of this tire issue at Rausch. As Charles kept saying, it is a testimonial to what a stock Defender is capable of!
ID:	48375   Click image for larger version
Old February 28th, 2012, 10:23 AM
Jason, I love those pics!! Thanks for posting them up
Old February 28th, 2012, 10:25 AM
No problem, don't worry I won't be on "Ed time" getting mine loaded up! Today or tomorrow I plan to get them on Picasa and then upload a monster zip file for download.
Again, nice work on the trails this past weekend!
Old February 28th, 2012, 10:47 AM
This is a good approach, but requires space to store the other set, and is also significantly more expensive. I'm pretty sure the space issue will be a problem for Ed.
Originally Posted by pendy
I'm here for the D's
Old February 28th, 2012, 10:59 AM
Naplm00
Matthew
The BFG all terrain are the tire to beat for on road manners and light to medium offroading. they are radial, tough offroad and last forever on road.
If you want a long lasting mud specific tire I had the Mickey Thompson baja claw radial on my 1996 F150 for over 50k
not my truck http://carphotos.cardomain.com/ride_...0009_large.jpg
unfortunately they suck on ice unless you get them siped
Old February 28th, 2012, 11:31 AM
Charles is right, I am not in a position to store multiple sets of tires or change them frequently.
I'm honestly not concerned too much about traction. I figure as long as the tires have average traction, I should be fine. What I learned at Rausch was that technique and the right line pretty much makes or breaks a run. At the worst, I just go around the bypass.
I have realized that once the spare tire goes on, my wheeling is over for the weekend. Because the only thing left after the spare goes is a flatbed ride back home, which is not cheap. So what I want is a tire that can take serious abuse to the sidewalls, especially when aired down. I'm honestly very suspicious of some of the manly looking radial tires out there. They just look to me like typical street tires with "off-road-looking" treads molded around the circumference.
You can see just how flat my tires look going down the hill. That's aired down to between 13-18psi. I'm pretty sure that folded sidewall is part of the reason that I tore my tire. Doug told me that he even saw my tire almost come off the bead earlier and that was while I was driving to the trail. That picture of the aired-down jeep tire is pretty much what I would like to avoid.
Mud seems to vary from somewhere between "brown colored water" and "glue" and I purposely avoid all varieties. I know some people can't resist mud, but I am not one of them. I am solely concerned about rock and sharp objects.
Old February 28th, 2012, 01:13 PM
Yeah you did very well on those clown tires, so clearly some driver credit needs to be given. Get whatever tread makes you happy at the stock size, with a stronger sidewall (and buy 5 ).
I think you should use pic #3 for you avatar.
charles
Old February 28th, 2012, 01:27 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
You could also use this photo for your avatar if you prefer!
FWIW, I ran blues and blacks all day at Rausch on a set of 285/75 BFG AT's behind Trevor and Charles with little more than some spotting and the usual rock stacking. And also, the fold of that MTR is what you want!
------ Follow up post added February 28th, 2012 01:29 PM ------
was trying to load the pic of your truck on the flatbed but for not working right now
Old February 28th, 2012, 01:58 PM
This:
ID:	48383   Click image for larger version
Old February 28th, 2012, 02:19 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
yes, thanks! not sure if it was forum or my network related but glad Ed could enjoy them either way!
Old February 28th, 2012, 04:50 PM
Here's a good justification to get the KM2's. Doug is sort of my new hero . I think you could fit a small bus under his wheel.
Old February 28th, 2012, 05:00 PM
There's something epic about Doug's disco when it climbs over stuff. I think it's because it's such a crazy tall truck - and all the air he gets
tire, tires
Tires: an odessy souza Misc. Chit-Chat 37 December 14th, 2009 05:57 AM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
Maxxis Buckshot Radial Mudders tuko Defender Technical Discussions 0 March 26th, 2005 07:38 AM
110 steel wheels and tires artm For Sale - Parts 3 January 21st, 2005 09:06 PM
BFG AT Ko tires for sale Seriesman For Sale - Parts 6 August 18th, 2004 11:09 PM
