BG Products - Defender Source
Old January 11th, 2005, 05:59 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
BG Products
BG Products offers products for engine flushing, transmission flushing, coolant systems flushes and fuel injection flushes with the use of their various products www.bgprod.com. They even say if you have less than 36K miles on your vehicle and have a transmission flush performed by their dealer they will warrant the transmission for the next 7 years/150K miles.
My truck is approaching 90K miles, isn't buring oil, doesn't overheat and gets 14+ mpg. Does anyone have an opinion on doing these flushes and/or using these types of products to clean your systems out as part of regular maintenance for high-mileage trucks?
Old January 12th, 2005, 09:48 AM
lobster's Avatar
lobster
Rob Goodall
1995 D90
I have heard from both Jag and Rover mechanics that BG is the only fuel injector cleaner that works. I use it every other oil change in both vehicles. I haven't tried the others.
1995 D90 ST
1999 Super V8
Old January 12th, 2005, 10:06 AM
1of40's Avatar
1of40
1of40
Thanks for the input. One shop I spoke to yesterday said they didn't think the engive flush can really do much more than remove varnish from non-moving parts (value covers, etc.). They said after an engine flush you have clean oil for about 10K miles, but that didn't necessarily mean all the damaging composits were being removed. Confusing. They also highly recommended the injector product which I'll probably go with.
Old January 12th, 2005, 01:02 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Made here in the air capital. Good stuff Maynard.
JP
Repeated flushes can clean out the gunk. Flush the next three oil changes.
legend in my own mind
Old January 12th, 2005, 01:52 PM
1of40's Avatar
1of40
1of40
When you say flush do you mean the full-blown hook it up to the machine type of flush (as they suggest), or do you mean just add the product in with the next three oil changes?
Old January 13th, 2005, 01:14 AM
pendy's Avatar
pendy
jim pendleton
89'd90
They have a product you can add to the oil before you change it. If you do this try to change your oil every 2000 miles because it leaves residue.
Follow the directions carefully.
JP
The machine is good also, just a little spendy.
Pelican Products Blowout pricing Maine 110 The Vendors Loft 3 July 27th, 2005 09:22 AM
Anybody use Rust Doctor products? Antonios Defender Technical Discussions 7 April 29th, 2005 08:14 AM
LaSalle products for 90 Chris Cox Defender Technical Discussions 2 October 4th, 2004 08:59 AM
Owner feedback for Raingler products wanted 007 The Vendors Loft 25 August 6th, 2004 03:35 PM
