Better Transfer case and tranny? - Defender Source
Old March 6th, 2011, 09:59 AM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
Hello all. I am buying my buddies 86 D110 and wanted to know if there were better factory transmissions and transfer cases that would still bolt up. It has whatever the factory setup is for a 2.5L gas engine. Where he is stationed now, he can get other Rover parts pretty cheap, so if there is a better setup, that will still bolt-up to the 2.5, please let me know. I will have to tell him what year and such to pick it from.
Thanks in advance.
Old March 6th, 2011, 10:21 AM
grnrvrs's Avatar
grnrvrs
Paul
88
IMO, unless the engine is is perfect shape, the real question is, what is a better engine than the 2.5p? Answer 200 tdi, 300 tdi, any LR v8 or non LR engines too 4BG1t, 4BD1t...
Old March 6th, 2011, 10:45 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
200 or 300Tdi mated to a K or L series R380 & LT230.
Or if you don't want to change the engine, a short bell housing K or L series R380 & LT230.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 6th, 2011, 05:58 PM
red64chevelle
Daniel Smith
I have sent a note to my buddy about getting a TDI200. I will see how he can make out with that.
Old March 6th, 2011, 07:19 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
The later G and H suffix LT77 boxes are much better than the early ones like the D. But are cheaper and easier to find than the short bell housing R380.
Old March 6th, 2011, 08:42 PM
red64chevelle
Daniel Smith
Ok, probably a dumb question, but where do you find the suffix?
Old March 7th, 2011, 01:59 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Suffix is the last digit of the serial number stamped on the transmission or xfer case. Xfer case serial is stamped on the back, lower left "corner" as you look at it from the rear of the truck. I don;t remember where the transmissions are stamped, and I got rid of all my old ones. It will be a stamped number, not a cast (raised) number.
Tony
1984 110 "Smokey" (sold)
Old March 7th, 2011, 05:56 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The parts for the 200, head etc, are getting a little harder to get than the 300 Tdi. I would think that you could get the 300 at about the same price as the 200. If your friend is in the UK there are a few engine re-builders that you could get a nice motor from. But then again you could get a replacement from a breakers yard. If you get one from a RHD Discovery and you have a LHD Defender you will have to get a Defender style Exhaust/intake as the discovery stuff will get in the way.
Land Rover 110
Old March 7th, 2011, 07:40 AM
...better factory transmissions and transfer cases that would still bolt up.
No. Are there better transmissions and transfer cases that did not come from Rover? Yes by a mile, but you have to figure out how to fit them. The NP435, the SM465, the T18, the Muncie 20...all better than Rover. For transfer cases it is hard to beat a Dana300, except maybe an Atlas.
While you're at it, drop in a nice Ford or Chevy small block.
Old March 7th, 2011, 09:13 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
If you are going to upgrade the motor while it is in the UK I would go for the 300 tdi and get the trans and t case that came with it.
If you want to keep the original motor and upgrade the transmission I would go for the short r380 from ashcroft.
http://www.ashcroft-transmissions.co...&productId=157
Originally Posted by o2batsea View Post
bla bla bla same old shit I say on every thread
Since you have nothing of value to add to this thread please step away from the keyboard.
Old March 7th, 2011, 11:56 AM
Yo, nice hostility there Dave. Did I write something to offend you, or are you just grumpy today?
Old March 7th, 2011, 01:24 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Nope I am in a good mood and happy today. You gave bad advice and posted your standard response that you post each and every time a motor / trans post comes up. The poster wanted to know if there was a stock trans that was better than the one that wAs installed in his early truck. Chances are it has a suffix d and they are known to be weak the later ones are more than up to the task and he even has the r380 as an option.
Your response was simply "NO" and that is incorrect
Old March 7th, 2011, 02:08 PM
You're just a hater.
Old March 7th, 2011, 02:18 PM
then its not a rover
Old March 7th, 2011, 04:32 PM
red64chevelle
Daniel Smith
I am thankful all the advise so far. I really want to keep it as a rover. I have thought about adapting a VW TDI engine. That would only be because I have a spare ALH. But other than that, I want a rover. My buddy is actually in Bahrain, not the UK. So, it is a nice left hand drive model from the desert. He has a line on a drivetrain from a 2000, so it is probably a 200TDI.
Old March 7th, 2011, 04:48 PM
2000 is a TD5.
1989-1993 = 200TDI
1994-1997/8 = 300TDI
1998 to 2006 = TD5
2007 to pre = TDCI
OK, let's step back. Why are you asking this question? Is there a problem with the gearbox?
Anyway...as stated, an engine swap is pretty common. If you go that route, keep the gearbox and transfer case that are with the donor engine as the strength and gearing will be correct.
1) 200TDI Defender is the easiest swap. All bolt on. Easy weekend job.
2) 200TDI Disco. Probably the cheapest of the Rover engine swaps. Requires a moderate amount of customization.
3) 300TDI. Mostly bolt in with all the donor truck parts other than engine mounts.
4) TD5. Mostly bolt in, but more work.
Old March 7th, 2011, 04:50 PM
2000my will most likely be a td5 or 300 tdi. 200 went out of production in 1993.
Old March 7th, 2011, 04:53 PM
Right, I was not thinking of "other" places in the world that still had the 300TDI after the TD5 came out. Can't recall when they finally stopped using it.
Old March 7th, 2011, 06:41 PM
red64chevelle
Daniel Smith
Oops, I meant 1990, not 2000. I am not really sure how I screwed that up.
I had heard that the early transmissions were on the weak side. Knowing that, I figured an upgrade would be in order. The engine, a 2.5 gas, has just had bearings, rings, and pistons done so its in good mechanical shape.
Now that I have a little more knowledge of all of this, I think I will try to get a TDI300, along with the tranny/transfer case, but if that does not work, than I will get the TDI200, along with its goodies. I just have to check to see if the 1990 he is looking at has the TDI200, and not the older TD.
Old March 7th, 2011, 09:06 PM
1990 should be a 200TDI. The earlier boxes have small layshaft bearings. You get a lot of notice before they leave you stranded as the bearings loosen up over time. Behind the 2.5 petrol, you are probably fairly safe...
There is no reason to get the 300 over the 200. Power and torque are the same. The 200 Defender version is a lot less work to install.
transfer case
Transfer case whine ini88 Defender Technical Discussions 30 May 7th, 2012 09:46 AM
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Transfer case shiftlock wingnut Defender Technical Discussions 0 July 27th, 2008 09:07 PM
Wanted, NAS 1995 D-90 (Tranny) Transfer case Roverville Wanted 3 November 28th, 2005 02:14 PM
Transfer Case Overfill D90user Defender Technical Discussions 19 May 10th, 2005 01:51 PM
