Better Heat - Defender Source
Old November 5th, 2011, 01:23 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Better Heat
Anyone ever install one of these? If so can you post some photos.
http://www.flex-a-lite.com/auto/html/mojave-heater.html
Old November 5th, 2011, 08:33 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
AlohaRover (Pete) did. IIRC he was happy with it.
KAA
Old November 6th, 2011, 09:28 AM
That would not be "better" than the stock heater, but could be used as a second heater.
Old November 6th, 2011, 10:14 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Any thoughts about installing a huge heater matrix in the cab? I'm thinking about fitting a matrix that comes from a school bus. That matrix is about twice as thick and 2-3 time larger than a defender one. It might cool down the engine but I figured that it could replace the engine front radiator. If there's not enough heat then the thermostat will stay close.. Am I missing something?
Old November 6th, 2011, 01:47 PM
Naplm00
Matthew
I was thinking about the other night might be interesting to just cut the heater box larger and put a second heater core in series with the first
Old November 6th, 2011, 08:25 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
In my opinion it's not the temperature but the air flow that is not sufficient. Those small air trap don't allow much air to pass..
Old November 6th, 2011, 09:55 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
more heat
Before you add a second heater you may want to consider opening up the vent in the dash. If you remove the plastic dash you will see that the whole in the dash is much smaller that the opening on the heater. Land Rover thought that a small hole in the dash would increase air flow on the far side of the dash but it does not.
If you cut the dash so the hole match the heater inlet the air flow increases and makes a huge difference. I did this to my old 94 NAS soft top and it was warm and toasty all winter in New England even w/o a drop curtain.
I think removing dash is the easier way but you can also remove the heater.
Best of luck!
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old November 7th, 2011, 05:18 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
It's true but even after this it is not really comfit in there. Perhaps a 110 is another beast to heat up as it is bigger. I fitted a webasto cab heater and it does wonder. The main ideal to plumb in another matrix is only to use the already heated water to provide heat instead of using diesel with the webasto.
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat Sheild Bowtracer Defender Technical Discussions 14 July 7th, 2007 12:11 AM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
