Bet This Happened to Someone Else - Defender Source
Old September 3rd, 2012, 04:23 PM
doscazadores
Vic Stull
none
A Torx bolt that fastens one of the rear roll cage uprights has had the pattern stripped by one of the 2 PO's or someone who worked on the truck for them. I'd love to know how to remove it now that it's fubared. Because the structure surrounding the bolt is so tight I can't figure out how to get at it.
Old September 3rd, 2012, 04:29 PM
giftshopduane
Chris luciano
72 Series 3 88"
Hammer an allen socket into it, how about a larger torx bit.. pics? Cold chisel at an angle counterclockwise? Sometimes a socket just small enough to be hammered onto the head can back it off.
Old September 3rd, 2012, 07:15 PM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
And some PB Blaster
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old September 3rd, 2012, 07:32 PM
61rover's Avatar
61rover
John Crouse
Or drill baby drill
Old September 3rd, 2012, 07:38 PM
I'm less patient yhan others-air chisel
Old September 3rd, 2012, 10:24 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
weld on a nut and use a socket...
Old September 3rd, 2012, 10:50 PM
Careful! Aluminum that thin burns easily!
Old September 3rd, 2012, 10:58 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I'm assuming that the roll cage bolt is stainless or mild steel, and the cage is certainly not going to be a problem. Another big plus is the heat on the bolt will certainly make removal of the nut a little easier.
Old September 4th, 2012, 07:34 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Get an easy out, simple fix. Those are 10mm I think so get one smaller than that. If you get a 1/4 inch one you just drill a 1/4 inch in the center of the damaged bolt, insert the easy out, applying a lot PB Blaster, as mentioned earlier, and it should come out.
Land Rover 110
Old September 4th, 2012, 02:50 PM
doscazadores
Vic Stull
none
I'm on a break at work right now and not looking at the truck. But the problem that I forsaw is that this bolt is kinda tucked away at the base of the upright. So drilling into it or welding on a nut, which is a good idea and had't occurred to me, seems nearly impossible because I don't think I can get at it at a 90 deg. angle. Again, this is based on my recollection. And I might have omitted that it's a '95 ST, passenger side pillar, rear
What happened to LenB/American Dirt Roads? Chaucer Misc. Chit-Chat 4 June 2nd, 2011 09:10 PM
It has finally happened for all of us.... Overlander Misc. Chit-Chat 59 November 25th, 2010 10:39 AM
Hey what happened to Discoweb and Disco2 forums? mudinyour Misc. Chit-Chat 2 January 20th, 2005 08:32 AM
What happened to the archery game draaronr Misc. Chit-Chat 2 December 28th, 2004 09:18 PM
Has this ever happened to you ? / Nicholas Orros.. Is this yours? norros Misc. Chit-Chat 20 July 8th, 2004 04:11 PM
