Bestop fit... - Defender Source
Old January 3rd, 2013, 11:05 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
What keeps this from happening??? New to me top. Thanks.
Old January 3rd, 2013, 11:11 AM
bjf's Avatar
bjf
barry f
94 ST #395
I recently saw a best top on a truck at a shop I frequent where it had no windows in yet the back was miles away from clipping in. The shop asked me if I thought it would fit and I wasn't sure. Do the best tops shrink that much? Will it need to be tossed in the trash? I said use a space heated but I really didn't see it stretching the four inches needed.
Old January 3rd, 2013, 11:17 AM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
I don't have my Bestop anymore, but it looks like you are missing the rubber weather stripping. Not sure how that would be though.
Old January 3rd, 2013, 11:19 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Brother says I'm missing a vertical bar. Only 97's came with it.
Old January 3rd, 2013, 11:23 AM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
The B Pillar vertical bar would help a lot, though your top looks to have shrunk quite a bit.
Old January 3rd, 2013, 11:39 AM
bjf's Avatar
bjf
barry f
94 ST #395
So can anything be done about the shrinkage?
Old January 3rd, 2013, 11:48 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
If its a 1997 top then it will have pockets for the vertical brackets.
Yes these tops shrink that much
Even a Badger Top will shrink over time.
With patience, time and heat they will stretch some.
What I do is usually put the top on without windows.
Then add one window only zipping in partially.
Hooking it to the belt rail while slowly rolling the top down as you zip.
Leave it on for a bit to acclimate to the stretch
then undo and do the other side.
Then try and do both sides. A helper will make it easier.
Once the sides are in comes the back window.
I will usually take the sides off the belt rail and partially zip in the back window.
I use my left hands to roll the top over the C pillar while synching the snap on the C pillar.
Once I have a good stretch i start zipping the top and sides
Take your time the zippers are prone to ripping.
I also will spray/clean the cage with some WD 40 before the install
Good luck
Old January 3rd, 2013, 06:10 PM
cwerlin's Avatar
cwerlin
Craig Werlin
1994 D90 #877 ST AA Yellow
Heat helps tremendously, hard in the winter but I isles to lay mine in the sun for a few hours prior to putting it on. Heated garage maybe, but really doesn't help unless it is above 80.
Old January 3rd, 2013, 06:14 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
its a 94 - so he is going to have to "tap" out the rivet and install a nutsert thing, so that the vertical bar can screw to something. =)
bestop
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
94 Bestop with 2 sunroofs CDN38 For Sale - Parts 6 October 23rd, 2005 09:29 AM
Bestop Windows Defender 90 YellowPaintMan Wanted 0 August 22nd, 2005 04:11 PM
Rear Bestop pass. window UpnOver Wanted 0 August 13th, 2005 02:26 PM
1994 D-90 Factory Bestop parts needed?? Adam Armendariz Defender Technical Discussions 2 March 30th, 2005 08:25 PM
