Best wiring layout for rollbar mounted off-roadlights? - Defender Source
Old January 23rd, 2011, 09:39 PM
Knife90
john sabra
'94 Defender 90
I"m looking for advice on how best to layout the wires/relays/switch/power wiring for 4 Hella50's mounted on the rollbar. Definitely a frustrating thing to try and figure out, but cant find a thread laying out a diagram. I bought a Hella wiring harness, which seems like more of a pain to deal with than its worth, and too bulky.
Specifically I'm trying to figure out best and neatest way to come off the roof with wiring access to the battery compartment and placing a dash mounted switch.
1. Where should the relays go?
2. Is the B-pillar best way to come down from roof in to batt compartment?
3. Should the switch wiring come down A-pillar to get to dash, or run under from batt compartment?
4. Best way to run 2nd power wire to accessory panel light switch?
If anyone has a link to direct me to that'd be great.
....or, if you're in Austin and can recommend good place to get this done "professionally", I'm willing to pay for it, as i'm beginning to think I bit off more than I can chew.
Thanks guys.
Old January 23rd, 2011, 10:38 PM
RoverNC's Avatar
RoverNC
James Wortman
1994 D90 #1693
Here's a link to get you started:
http://www.defendersource.com/forum/...ighlight=hella
Are you heading to SCARR in April?
Old January 24th, 2011, 08:20 AM
Knife90
john sabra
'94 Defender 90
thanks, will take a look.
planning on SCARR for sure unless work gets in the way!
Old January 24th, 2011, 08:37 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Bolt size for the light tabs are 8mm x 1.25 pitch...(thanks mike @ecr)
Old January 24th, 2011, 01:44 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Thanks guys.
This is definately something you can do yourself...it is very easy....
I can post more details if you need it.
I ran all of the wires down the roll cage in black wire loom and into a gap between the hood and the firewall...no drillilng and you can not see them.
I also extended all of the grounds to get a good ground instead of grounding to the roll cage.
I ran 4 guage wire from the battery to a post under the hood (drivers side fender) and connected all the relays under the hood.
You can then run the switch wires through the bungin the dash that the speedo, etc goes in.
You can then get ignition switched power for the switches from the fuse box.
Here are some simple pics:
http://www.defendersource.com/forum/...ad.php?t=25754
Dave
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old January 24th, 2011, 04:16 PM
Knife90
john sabra
'94 Defender 90
Dave, thanks. If you have any more pics i'd appreciate it.
1. did you splice all the grounds into one wire on the cage, and then just run one ground wire into the engine bay? or run 4 grounds into the bay?
2. is it best to use 2 relays for the 4 lights? or could i get away with one?
3. what do i hook the purple Hella harness wire into if i choose not to link up with the high beams? my preference is to be able to turn the aux lights on even w/o the parking lights or reg lights on, with the ignition key in position two. is that possible?
thanks for any/all advice.
Old January 24th, 2011, 05:01 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
I ran 4 separarte grounds.
Use 2 relays (some use 4...but that is overkill IMHO)
Hook it to the ignition powered source that you use for the switch. this will draw very little so you can splice all of them to one. I have them on my high beams so I don't accidentally melt the covers...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old January 25th, 2011, 09:04 AM
Knife90
john sabra
'94 Defender 90
Thanks, that definitely helps straighten some things out in my head.
ht, lights, mount, wiring
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Some wiring Diagrams Mike Hippert Defender Technical Discussions 5 March 9th, 2005 11:14 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
