best way to remove rusty door hinges?? - Defender Source
Old July 5th, 2011, 10:36 AM
bar11's Avatar
bar11
rob grentz
1994 defender 90
I kno this may seem like a silly question but hey arn't they all, I am replacing my doors on a '94 d-90 and the hinges are the ones that came with the truck they are rusty as heck and won't budge even after a good soaking..... I'm looking for any tips/tricks Thanks in advance
Old July 5th, 2011, 10:42 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Try an impact screwdriver. If that fails drill the screws out.
Old July 5th, 2011, 10:44 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
What Kevin said. I had to drill through mine. It's easier if you can grab the bolt on the inside so it doesn't spin when you drill:
http://www.defendersource.com/forum/...7&postcount=83
MUDSUX
Old July 5th, 2011, 01:30 PM
Impact screwdriver. $30 or so at sears.
Old July 5th, 2011, 02:30 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I had decent success with a bolt/screw extractor set I got at sears. I busted several of the grabit style - they were fine for lighter duty, but could not stand up to the doors.
Old July 5th, 2011, 02:57 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
IF the hinges are totally FUBARd, then a thin angle grinding blade and just slice through the whole hinge until you cut through the bolts.
Then replace with stainless hardware.
Old July 5th, 2011, 03:20 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I recently replaced all of the original hinges on my '85 110. Some of the bolts were so rusted that they wouldn't budge, even with a good soak of penetrating lube. I had to drill a few of them out. I replaced the old hinges with TD5 hinges and used stainless hardware from Nakatanenga 4x4. I agree that if you can secure the nut on the other side, it makes removing them easier. Of course this next to impossible with the j-nuts. (have fun trying to retrieve those from your bulkhead if they fall in)
ATW!
- Jon
Old July 5th, 2011, 06:12 PM
The lower J-nuts are the problem.... Usually seized solid. Impact screwdrivers only go so far. I agree drill the head of the screws off is the easiest.
Old July 6th, 2011, 07:36 AM
bar11's Avatar
bar11
rob grentz
1994 defender 90
Thanks guys I got the project done as I was only replaceing the doors and the hinges were good i was able to access the nuts from inside the door and tapped them out with a punch leaving the part of the hinge that is attached to the bulkhead in place.. Thanks for all the help
door
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
remove front diff? scoloco Defender Technical Discussions 31 April 7th, 2005 03:23 AM
Why not remove the inner bushing sleeve? ezzzzzzz Defender Technical Discussions 0 June 10th, 2004 07:00 PM
How to remove radio in 97 SW? BarryO Defender Technical Discussions 2 March 5th, 2004 06:08 PM
