Best way to reduce fuel line - Defender Source
Old July 2nd, 2016, 11:45 AM
Matt_110's Avatar
Matt_110
Matt
110
Since I put the correct fuel pickup/sender on, I noticed the inlet requires an 8mm hose. I had 3/8 hose going to my previous sender (I don't have stock fuel lines). What is the best way to reduce the 3/8 ID hose to the 8mm "neck" on the sender/pickup? Would a barbed adapter do the job securely? 90* elbow would be ideal since I'll need to go from the left side of the tank, up and over to the right side of the chassis.
Thanks!
110 w/2.8tgv
Old July 4th, 2016, 01:13 AM
Greg S
Greg Sutfin
1986 90
Would a hose clamp work? If you choose that route, use two quality ones the right size.
Old July 4th, 2016, 04:34 AM
X2 on the hose clamp. The fewer connections as possible reduces leakage potentiometer.
Old July 4th, 2016, 08:00 AM
I hate autocorrupt.....correct
Old July 4th, 2016, 10:24 AM
Matt_110's Avatar
Matt_110
Matt
110
Thanks all...I'll give a couple hose clamps a whirl. The 3/8 isn't too much bigger. I agree on keeping it simple
1987 110, 2.8TGV, ZF Auto
Old July 4th, 2016, 12:11 PM
Naplm00
Matthew
I like the bmw style/Fuel injection hose clamps for these jobs.. They tend to hold better
fuel
Best way to clean inside of fuel tank? sonoronos Defender Technical Discussions 54 January 31st, 2012 02:50 PM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
how to reduce the tire diameter 4 inches? cdb Defender Technical Discussions 3 February 16th, 2010 11:34 AM
3 Link Angles To Reduce Vibs ? jorge Defender Technical Discussions 1 December 31st, 2005 02:36 PM
photo sizes - how to reduce paulb Support & Suggestions 2 November 26th, 2003 05:12 PM
