Best VALUE adding MOTOR SWAP for older 110 in USA? - Defender Source
Old March 23rd, 2016, 12:45 AM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
In your opinion, what is a readily available (crate if necessary), decently easy motor to swap into a late 80's Defender 110 to add value in the USA ? LS, Tdi300, TD5, Cummmins etc..
Thanks guys
Old March 23rd, 2016, 12:57 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Haven't done it yet, so I have little to add other than the "ease" could be further defined if we knew if the said '80's 110 was already diesel.
Old March 23rd, 2016, 01:00 AM
Landy_Andy's Avatar
Landy_Andy
Andy
LS all the way.... But I'm biased
Old March 23rd, 2016, 01:22 AM
D90Overkill
David Frank
1995 ST #2615
Originally Posted by Landy_Andy View Post
LS all the way.
No doubt! Possibly not the easiest, though.
Old March 23rd, 2016, 01:38 AM
WestCoastRover
Jeff
2000 TD5
It's a 2.5L Gasoline, Not my first choice!
Old March 23rd, 2016, 09:19 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
There is lots of trash talk about Rover V8s but I think it is not all warranted. People are "giving away" 3.5 V8s and that might be your cheapest and easiest way to make the Rover have better road manners and more attractive to resell.
It is not the fastest / strongest / most anything motor - but it is good and cheap and easy.
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 23rd, 2016, 09:22 AM
Cheapest... 3.5 or 3.9 with a carb setup... And an r380
95' D90 - daily driver..
Old March 23rd, 2016, 09:30 AM
a 4.2 with edelbrock carb and manifold will put a smile on your face.
CJ's FJ's Avatar
CJ's FJ
CJ
1985 90
I've wondered this also. Does it hurt or help the value of the vehicle to pull out an old carb'd V8 and replace with 3.9 or 4.0 efi? Does it make more sense to convert the "old" V8 to efi?
Old March 23rd, 2016, 09:41 AM
Gas Turbine. Only one moving part.
Old March 23rd, 2016, 09:51 AM
rovertrader's Avatar
rovertrader
Dale
The tough part of this question is not what is best, but what is most accepted/wanted if you are talking 'value'. I have put in a Tdi for one customer, only to remove it for an Efi petrol for the next. Opinion is hard to build for speculatively.
I agree the Rover V-8 is solid, makes moderate power, and is the economical way to go. But if the buyer is a diesel junkie, it isn't a Rover if it isn't puffing...
Old March 23rd, 2016, 10:19 AM
supercharged67gt's Avatar
supercharged67gt
Andy
64 series IIa x3
anything non land rover would make it better...
Old March 23rd, 2016, 10:43 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Glad someone else read the question...
My opinion is that the best resale dollars will be an engine/transmission package to a traffic speed automatic - probably the TD5 for range, fuel economy, sufficient power and speed to keep up and not out-drive the rest of the truck.
Old March 23rd, 2016, 11:50 AM
D90Overkill
David Frank
1995 ST #2615
Regardless, will this will be done in Canada or on a titled US truck? Timing is everything ;-)
Old March 23rd, 2016, 12:40 PM
BlackField's Avatar
BlackField
Oscar
D110
That's not really true. All turbines have an accessory section with a bunch of tiny moving parts.
My vote for engine is.... Ecoboost 2.0 boom. I said it.
Old March 23rd, 2016, 12:46 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
I like the Chevy 4 cylinder turbo charged engine. Same engine in the Cadillac ATS.
LTG Four-Cylinder Engine: 2.0L Small Block | Chevrolet
Old March 23rd, 2016, 12:57 PM
WestCoastRover
Jeff
2000 TD5
Which suitable Rover V8 are we referring to here? 4.0fi? and what transmission should go with it.
And yes, the most accepted motor is the goal. Not the "best" or there would be an LBZ duramax going in
The plan is to export the Defender 110 from Canada, and register it in WA. After succesful import the motor swap will be done to create a clean Defender capable of a daily driver and highway friendly.
Old March 23rd, 2016, 02:14 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Honestly, look at the LS & 6 speed option. With Marks kit of parts and a good low mileage used motor you won't go wrong. Plenty of power for towing, fair fuel economy and easy driving on the highway, and service parts are cheap to boot.
Rover V8's are OK but why put up with an old technology ZF auto when you can have a nice modern 6 speed.... just my CDN 2c
Old March 23rd, 2016, 02:39 PM
WestCoastRover
Jeff
2000 TD5
Which LS engine and 6 speed should I look to get?easy to find used?
And marks kit? Thanks again for the help guys
Old March 23rd, 2016, 02:42 PM
It is Nick, not Mark... nmarkiw on here. Contact him directly for pricing and information.
http://www.defendersource.com/forum/...-ls-51290.html
110, motor
Adding Electronic Sensors to Older Defenders richord Defender Technical Discussions 11 August 19th, 2014 03:42 PM
Motor value ?? Nomar Misc. Chit-Chat 14 December 11th, 2013 02:41 PM
Value of a 300Tdi motor FLRover Misc. Chit-Chat 9 May 18th, 2013 01:12 PM
Range Rover Engine Swap- Potential Value Issue? Montgo1715 Misc. Chit-Chat 5 April 12th, 2010 08:12 PM
Added value of a 4.6 swap evilfij Misc. Chit-Chat 5 July 28th, 2006 10:02 AM
