Best VALUE adding MOTOR SWAP for older 110 in USA? - Page 2 - Defender Source
Old March 23rd, 2016, 04:12 PM
rovertrader's Avatar
rovertrader
Dale
Nick is the LS guru, Mark's is an adaptor from Oz to mate SBC to R380/ZF
Old March 23rd, 2016, 09:35 PM
Originally Posted by rlynch356 View Post
Cheapest... 3.5 or 3.9 with a carb setup... And an r380
Late 80's rover I still think this is the best for resale and ease of parts and install... V8 keeps it rover, etc..
It is not the best combo but for the question I think it is (or a 4.2 as Doug says )
95' D90 - daily driver..
Old March 23rd, 2016, 11:35 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
If it is an RHD original condition and solid but still a some rough edges I say go with the 4.2 carb'd like Doug said.
If you are doing some other work/restoration like RHD->LHD and some interior updates then LS. I would wager the LS / Auto / LHD configuration with a nice interior would be the easiest to sell once done.
Burly trail rig with say 37's / HD axles and a bunch of armor: 6BT or a hi pow gas
Mid duty off road and all around build? My vote is OM617 (which is what I am doing) or 200/300tdi.
Old March 24th, 2016, 12:47 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I swapped my 3.5L V8 for a 3.9L EFI out of a '94 D90 in my driveway. Relatively easy (my 1st engine swap ever) with the "hardest" being figuring out the wiring. Mind you, yours is a 2.5L, so I assume new engine mounts will be needed.
I went with the 3.9 over the 4.2 only because I bought it cheap. I would go with the 4.2 EFI.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old March 28th, 2016, 04:52 PM
RoverMike
Michael Shea
Need one...
Originally Posted by WestCoastRover View Post
Which LS engine and 6 speed should I look to get?easy to find used?
And marks kit? Thanks again for the help guys
Vortec 5300 High Output would be a good donor motor for a Defender without the price tag of an LS7 or some of the other highly sought after lumps.
Old March 28th, 2016, 05:50 PM
How much money do you have and how much money do you need to make? I think that matters more than what is "more accepted"...There is a huge variation in cost with the options
2.8TGV, 200tdi, 300tdi, Isuzu 4BD1T, Mercedes OM617, Cummins 4BT, TD5, Duratorq 2.4L, BMW I6, then all flavors of Rover V8's...
like others have said, there is also an SBC swap.
Then choose a transmission, factor in new driveshafts depending on changes to the driveline.
Then factor in all the ancillaries.
Then reconsider what you're trying to do
Old March 28th, 2016, 10:48 PM
tmorris1076's Avatar
tmorris1076
Tyler Morris
1986 defender 110 LHD 300 Tdi r380
geez...how would you not choose an LS for the US of A...any knucklehead can work on it and parts are given away free almost at any parts store...don't overcomplicate things...plus when you hit the skinny pedal it will merge into traffic no problemo...
Old March 29th, 2016, 11:53 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
MY answer is not from the perspective of someone who has sold vehicles, but someone who would be buying a Rover.
While no Rover is a perfect, original, parts matching vehicle, I am someone who values Rovers enough to own one. Therefore, I am drawn to one that has sensible Rover upgrades. I'd be drawn to one with the best possible ROVER engine in it. For me that would mean one of the V8s with EFI, a 300TDI, or a TD5. They're a reasonable upgrade, that COULD have been found in any of our trucks. While dropping an LS in there isn't radically changing the overall "Defenderness" of the truck, and acknowledging this comparison is a bit of hyperbole, it feels a little like the Defender rock crawlers that are so far departed from a Defender, that I wonder why they bothered to start with one.
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old March 29th, 2016, 12:44 PM
phoenix37's Avatar
phoenix37
john
The "rover V8" is a buick motor with rover stamped on the valve covers...is it really changing the rover DNA to swap out the "vintage" small block GM V8 for a more modern one? But again to the original post I haven't seen any LS Defenders on the market so its tough to say how they will be valued.
Old March 29th, 2016, 01:23 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I wonder how much heat the LS throws off. Warm days make it tough for me to use the D's with others in the truck.
110, motor
Adding Electronic Sensors to Older Defenders richord Defender Technical Discussions 11 August 19th, 2014 03:42 PM
Motor value ?? Nomar Misc. Chit-Chat 14 December 11th, 2013 02:41 PM
Value of a 300Tdi motor FLRover Misc. Chit-Chat 9 May 18th, 2013 01:12 PM
Range Rover Engine Swap- Potential Value Issue? Montgo1715 Misc. Chit-Chat 5 April 12th, 2010 08:12 PM
Added value of a 4.6 swap evilfij Misc. Chit-Chat 5 July 28th, 2006 10:02 AM
