Best US source for D90 rear crossmember? - Defender Source
Old August 21st, 2012, 11:40 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Looking for a rear cross member for a NAS 90. RN has the galvy NAS and non-NAS in painted steel. Any other good options for the NAS part?
Tony
1984 110 "Smokey" (sold)
Old August 21st, 2012, 12:48 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Large batch of rear cross members are on the ground. These are genuine and not galvanized or painted.
$275.00 for either one. The 90 ones are the closest to NAS as you can get.
Call the shop if interested. We have 10 of each.
6367 East Colonial Dr. Ste. A
Orlando, FL
(407)517-4983
info@safarihp.com
Old August 21st, 2012, 01:13 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Thanks man!
Tony
Old August 23rd, 2012, 11:45 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Can you elaborate? Are these NAS or not? Shipped from FL or VA?
Old August 24th, 2012, 12:34 AM
I would caution you that unless you are sure the rot does not extend into the rails and are ok pulling the tub, you are much better off with one with extensions.
Old August 24th, 2012, 07:29 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
As mentioned check the bottom of the frame rail as they rust from in the inside out.
Looks like Clay pulled the Link from Safari Heritage Parts site.
Land Rover 110
Old August 24th, 2012, 07:31 AM
1of40's Avatar
1of40
1of40
These are for sale by a Vendor on this board in Fla. Call that number and they'll be able to help.
Clay
Old August 24th, 2012, 07:32 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
So the tub has to go in order to replace the crossmember? I'm guessing to get access to where the crossmember meets the rails? Hmmmmm....
Old August 24th, 2012, 08:56 AM
Tub has to come off do you can weld all around the chassis rails
90, d90
WTB: Rear 110 crossmember piekas Wanted 0 September 7th, 2011 01:27 PM
Anyone know of a US source for rear quarter panels? Turbofan Series Technical Discussions 2 May 6th, 2011 07:27 PM
Rear Crossmember Source isleofbones Defender Technical Discussions 2 March 25th, 2010 06:26 PM
Folding rear step on NAS rear crossmember Overlander Defender Technical Discussions 4 September 15th, 2008 09:33 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
