Best tranny oil for lt77 - Defender Source
Old January 14th, 2013, 04:53 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I have been searching and reading on the lt77 vs r380 transmissions trying to figure out what is the best oil. I am not having any issues at this point but do notice that it takes a little slower shifting from 1st to 2nd. I am not hearing gears grind but I can feel the slightest vibration sometimes, not with every shift.
I figured it would be a good time to put new tranny oil in. I have heard people say Redline MTL, ATF type F and so on. What do you recommend?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 14th, 2013, 05:08 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
This is what I am running:
http://www.amsoil.com/shop/by-produc...?code=ATFQT-EA
It has helped out the shifting a lot.
Old January 14th, 2013, 05:40 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
I'm using Redline MTL. They stock it at 3R in Englewood.
Old January 14th, 2013, 07:15 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I couldn't get my hands on any Redline at the time (when I had my old 110 with a lt77), so the local speed shop recommended Royal Purple synthetic ATF. It worked well enough. No additional seal seeping.
Old January 14th, 2013, 07:41 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Old January 14th, 2013, 07:48 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I get my redline mlt from amazon buy three ships free
$14.95 ea
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 14th, 2013, 09:36 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks for the advice, looks like I will do the Redline MTL
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 14th, 2013, 09:56 PM
meatblanket
Mike Simpson
It might be a good idea to change the filter as well or at least clean the existing one out after you drain the fluid.
Old January 15th, 2013, 09:29 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
In lieu of draining all the fluid (will wait for a sunny warm day for that) can I just add the Redline MTL into whatever is in their now or should you start fresh with one kind? Not sure what is in there now...
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 15th, 2013, 09:36 AM
meatblanket
Mike Simpson
I don't know one way or the other about mixing it, but if you don't know when it has been changed last, then I'd go ahead and drain the transmission when that warm sunny day materializes. You'll need 3 quarts and you'll have some left over. If you get a new filter, get some new sealing washers at the same time.
Old January 15th, 2013, 09:41 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks Mike, where can I pick up a filter? Is that just a common size at the local auto parts store?
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 15th, 2013, 09:48 AM
The filter is meant to be cleaned. It is just a strainer.
Old January 15th, 2013, 10:07 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Technically the answer is sure but other than a few minutes of discomfort, I would bite the bullet and drain the fluid. Whole process should only take you 15 minutes as long as you have a fluid pump (which you will want either way) and will give you the piece of mind of knowing that your transmission is happy again!
Old January 15th, 2013, 10:11 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Anyone local in the Denver area want to help me do this? I don't have a fluid pump, and would rather have someone watch that knows what the hell they are doing before I try it alone.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 15th, 2013, 10:38 AM
bjf's Avatar
bjf
barry f
94 ST #395
Few things:
You can't add without draining. You basically fill it up to the fill hole so unless you drain you have no place to put the fluid. In addition it would be pointless to mix the fluids. If there really is a benefit to the redline stuff you wouldn't see it. For what it is worth I run Royal Purple in everything.
You don't need help doing this. You just need a $5 pump. Only suggestion is make sure the fill plug is removable before you take out the drain plug.
Where is there a strainer/filter in the tranny? News to me.
Old January 15th, 2013, 10:56 AM
The strainer comes out with the large drain plug.
Old January 15th, 2013, 10:59 AM
http://www.landyzone.co.uk/lz/f41/lt...ge-134455.html
Old January 15th, 2013, 11:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
Is that in an r380 too? I've never seen that before.
Old January 15th, 2013, 11:13 AM
meatblanket
Mike Simpson
Rovahfarm has the filter, seals, etc.
It is likely that you can re-use the filter unless it's torn or gummed up really bad. But they are quite inexpensive.
Note there are two drain plugs, so you'll need two sealing washers, one big and one small. You can re-use the sealing washers as well, but again, they are cheap and after putting nearly $50 in new fluid in there why risk a drip?
It's a super easy job but can be a bit messy using a fluid transfer pump.
If you want help I'll volunteer when it's warmer out.
Old January 15th, 2013, 02:21 PM
The strainer for the R380 is inside the box and not serviceable.
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
