Best replacement front door hinges - Defender Source
Old January 25th, 2014, 04:13 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Can someone clue me in on the best door replacement hinges? Giving up on the old ones for my '97.
-Ren Ching
Old January 26th, 2014, 02:48 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I went through this search last year... I ended up with the newer td5 style hinge... There are other alternatives but they are very expensive... Stay away from the britpart stuff... Horrible tolerances... You may as well just put the old ones back on...
Old January 26th, 2014, 07:53 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
The CroyTec ones look interesting:
http://www.croytec.co.uk/products.htm
Old January 26th, 2014, 10:12 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
I have Smiling Hound 316L stainless steel hinges on mine. They're a little expensive and blingy but they will last forever and can be media blasted and painted. Their site is here: http://smilinghound.co.uk/hinges.html
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old January 26th, 2014, 10:44 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
The stainless ones look like a nice factory looking replacement.
Any issues with galling in the hinge pin?
Old January 26th, 2014, 01:15 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
No galling yet. Three of them tend to migrate and have to be tapped back into place every couple of weeks. Down the road I'll tap in set screws and flush grease fittings for easy servicing.
Old January 26th, 2014, 03:05 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
How about galvanizing the original hinges with stainless screws? something I am thinking of doing... not too keen on aluminum hinges (w/steel screws).
Old January 26th, 2014, 03:37 PM
You need to figure out a way to make the pins work.
Old January 27th, 2014, 12:46 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
The new td5 hinges have a plastic bushing that prevents the pins from rusting out and dripping rust like the old style ones do... The cryotec ones are the cats ass but they are about $600... And they will eventually wear out too..
Old January 27th, 2014, 12:03 PM
michael67's Avatar
michael67
Michael White
110 Tdi
I've got the aluminum hinges. They're Britpart-labeled but I don't know if Britpart actually makes them. Came with all hardware -except- new mirror screws - the old ones don't fit. Good fit and no problems so far (four months on), although if you have the soft top doors like me you may have to trim the door capping a bit due to the larger size.
Old February 6th, 2014, 04:07 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Any recommendations on the best place to find solid td5 hinges?
Old February 6th, 2014, 04:24 PM
http://www.rdsparts.com/defender.htm
genuine ones are great ... cheap pattern parts are pretty crap
Old February 6th, 2014, 10:53 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I bought mine from rovers north... They have a complete set with all new shims and bolts etc... Pricey but if you do it, might as well do it right...
ac, door
Fan replacement davedeojay Defender Technical Discussions 10 March 23rd, 2005 02:00 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
front plate mounting souza Defender Technical Discussions 10 August 27th, 2004 11:12 AM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 0 August 10th, 2004 01:41 PM
