Best product/way to clean Badger windows - Defender Source
Old May 7th, 2014, 12:12 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Any product out there that does a good job cleaning Badger windows? Mine are getting a little cloudy.
Old May 7th, 2014, 03:23 PM
I thought he had some suggestions on his website, no?
Old May 7th, 2014, 03:31 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
There's a link...but no content
Old May 7th, 2014, 04:01 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I've used this product in the past.
http://www.westmarine.com/plastic-cl...13oz--10909422
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 7th, 2014, 04:59 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I like Meguir's Clear Plastic Polish and Clear Plastic Detailer. It is a two part system but works pretty good at getting rid of haze.
Old May 8th, 2014, 10:11 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I've developed a sort of clear plastic care ritual after years of owning Brit convertibles and aircraft. Piper windshields are expensive...
The key is getting the window absolutely clean before you start as any grit will only make matters worse. Use lots of water and mild compatible soap to clean the windows.
If it is clouded, you need to start w/ a cleaner like Meguires to restore clarity, then polish/protect with either their polish or something like 210 aircraft canopy polish. I prefer the 210, it cleans well and leaves a good protective coating. Once you remove the clouding, use the wash and 210 combo whenever needed.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
97 D90 Built WAY WAY Less than low book mightymg For Sale - Vehicles 11 June 6th, 2013 08:42 PM
Best way to clean inside of fuel tank? sonoronos Defender Technical Discussions 54 January 31st, 2012 02:50 PM
Contura Switch 3 way and 2 way Rugbier Defender Technical Discussions 21 January 26th, 2009 11:45 PM
Help with Ex-tec product into the States lactic Defender Technical Discussions 8 October 20th, 2006 11:30 AM
New truck product--BRAVO Davis Misc. Chit-Chat 17 October 10th, 2006 10:50 PM
